Revision: 12074
Revision: 12074
Author: gruehle@adobe.com
Date: 2009-11-20 17:02:03 -0800 (Fri, 20 Nov 2009)
Log Message:
Change baseColor to chromeColor.
QE notes: Tests need to be updated.
Doc notes: ASDoc has been updated. Other docs need updating.
Bugs: SDK-24298
Reviewer: Ely
Tests run: checkintests, qe cyclone
Is noteworthy for integration: Yes
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-24298
Modified Paths:
flex/sdk/trunk/development/eclipse/flex/sparkTest/src/SkinTest.mxml
flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/SparkChromeWindowedApplicationSkin.mxml
flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/WindowedApplicationSkin.mxml
flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/windowChrome/MacTitleBarSkin.mxml
flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/windowChrome/TitleBarSkin.mxml
flex/sdk/trunk/frameworks/projects/framework/asdoc/en_US/mx/controls/examples/SimpleProgressBar.mxml
flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/docs/mx.core.xml
flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/docs/mx.core.xml
flex/sdk/trunk/frameworks/projects/framework/bundles/ja_JP/docs/mx.core.xml
flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/docs/mx.core.xml
flex/sdk/trunk/frameworks/projects/framework/defaults.css
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/DateChooser.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/Label.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/LinkButton.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/SWFLoader.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/TextInput.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/Application.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ScrollControlBase.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/UIComponent.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/preloaders/SparkDownloadProgressBar.as
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/BorderContainerExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/ButtonBarExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/components/examples/TabBarExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/examples/DescendantSelectorExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/examples/IDSelectorExample.mxml
flex/sdk/trunk/frameworks/projects/spark/asdoc/en_US/spark/styles/examples/PseudoSelectorExample.mxml
flex/sdk/trunk/frameworks/projects/spark/defaults.css
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Application.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/RichEditableText.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/GroupBase.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/SkinnableComponent.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/SparkSkin.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarFirstButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarLastButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarMiddleButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxTextInputSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarThumbSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderThumbSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ListSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperTextInputSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/RadioButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarDownButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarLeftButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarRightButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarUpButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerDecrementButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerIncrementButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TabBarButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextAreaSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextInputSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TitleWindowSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarThumbSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderThumbSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/FullScreenButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/MuteButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/PlayPauseButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubBarSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubBarThumbSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubBarTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/VolumeBarSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/VolumeBarThumbSkin.mxml
flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/VolumeBarTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/AccordionHeaderSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/BorderSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarFirstButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarLastButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonBarMiddleButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/CheckBoxSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ColorPickerSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ComboBoxSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DataGridHeaderBackgroundSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DataGridHeaderSeparatorSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserNextMonthSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserNextYearSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserPrevMonthSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DateChooserPrevYearSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/DefaultButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/EditableComboBoxSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PanelBorderSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/PopUpButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ProgressBarSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ProgressBarTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/RadioButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarDownButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarThumbSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/ScrollBarUpButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderThumbSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/SliderTrackSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperDecrButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/StepperIncrButtonSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TabSkin.mxml
flex/sdk/trunk/frameworks/projects/sparkskins/src/mx/skins/spark/TextInputBorderSkin.mxml
