0 Replies Latest reply on Nov 20, 2009 6:16 PM by Peter Farland
    [svn:fx-trunk] 12077: Although Spark RichText does not support link formats , modifying compiled FXG to not generate ActionScript code that will cause compile time exceptions .
    Peter Farland Level 3
      Revision: 12077
      Revision: 12077
      Author:   pfarland@adobe.com
      Date:     2009-11-20 18:16:32 -0800 (Fri, 20 Nov 2009)
      Log Message:
      Although Spark RichText does not support link formats, modifying compiled FXG to not generate ActionScript code that will cause compile time exceptions.
      Removing references to Flex Builder 3 in RPC.
      QE notes: N/A
      Doc notes: N/A
      Bugs:
      SDK-24305 - Link format property nodes cause errors on RichText in FXG 2.0
      SDK-24322 - A couple references to Flex Builder 3 in Flex 4 LangRef (and code comments)
      Reviewer: Deepa
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24305
          http://bugs.adobe.com/jira/browse/SDK-24322
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/rpc/src/mx/rpc/xml/XMLDecoder.as
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/fxg/FlexFXG2SWFTranscoder.java
