3 Replies Latest reply on Nov 22, 2009 10:32 AM by tylershep123
    Drop down box
    tylershep123
      hi i am currently trying to make a dropdown box and i can not get the combo box to work correctly so i want to try another item.
      I was wondering if there was a way that when i roll over a "button" that a box opens up with the other options to choose to navigate through.
      so in other words u roll over the button, the box drops down, and the other boxes or the text in the dropdown box is clickable. thank you for your time.
        • 1. Re: Drop down box
          harihisu Level 2
          Is this what you want?
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
               verticalGap="0"
              <mx:AnimateProperty id="dropBox"
                   target="{dropDownBox}" property="height"
                   toValue="50" duration="500"
              <mx:LinkButton
                   label="Drop down Button"
                   width="150"
                   rollOver="dropBox.play();"
              <mx:VBox id="dropDownBox"
                   verticalScrollPolicy="off"
                   horizontalAlign="left" verticalAlign="bottom"
                   backgroundColor="white"
                   width="150" height="0"
                   <mx:LinkButton label="Button 1"     />
                   <mx:LinkButton label="Button 2"     />
              </mx:VBox>
          </mx:Application>
          • 2. Re: Drop down box
            Subeesh Arakkan Level 4
            You can use the open() method of the combobox to open it explicitly on roll over
            <mx:ComboBox id="combobox" mouseOver="combobox.open()"/>.
            • 3. Re: Drop down box
              tylershep123 Level 1
              THE CODE WORKED!
