0 Replies Latest reply on Nov 21, 2009 8:56 PM by Peter Farland
    [svn:fx-trunk] 12087: Dev only. Checking in Flash Builder 4 " Library Projects" for building Flex SDK SWCs in trunk.
    Peter Farland Level 3
      Revision: 12087
      Revision: 12087
      Author:   pfarland@adobe.com
      Date:     2009-11-21 20:56:09 -0800 (Sat, 21 Nov 2009)
      Log Message:
      Dev only. Checking in Flash Builder 4 "Library Projects" for building Flex SDK SWCs in trunk. These projects are easier to import and do not require linked resource variables to be specified.
      Note: although the trunk does not build textLayout.swc, there appears to be a legitimate compiler error in FlowGroupElement.as as a cast is missing. I'll follow up with TLF.
      QE notes: N/A
      Doc notes: N/A
      Bugs: N/A
      Reviewer: N/A
      Tests run: N/A
      Is noteworthy for integration: No
      Modified Paths:
          flex/sdk/trunk/build.xml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/airframework/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/airframework/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/airframework/.project
          flex/sdk/trunk/frameworks/projects/airframework/.settings/
          flex/sdk/trunk/frameworks/projects/airframework/.settings/org.eclipse.core.resources.pref s
          flex/sdk/trunk/frameworks/projects/airspark/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/airspark/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/airspark/.project
          flex/sdk/trunk/frameworks/projects/airspark/.settings/
          flex/sdk/trunk/frameworks/projects/airspark/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/flex/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/flex/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/flex/.project
          flex/sdk/trunk/frameworks/projects/flex/.settings/
          flex/sdk/trunk/frameworks/projects/flex/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/framework/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/framework/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/framework/.project
          flex/sdk/trunk/frameworks/projects/framework/.settings/
          flex/sdk/trunk/frameworks/projects/framework/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/halo/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/halo/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/halo/.project
          flex/sdk/trunk/frameworks/projects/halo/.settings/
          flex/sdk/trunk/frameworks/projects/halo/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/osmf/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/osmf/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/osmf/.project
          flex/sdk/trunk/frameworks/projects/osmf/.settings/
          flex/sdk/trunk/frameworks/projects/osmf/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/rpc/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/rpc/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/rpc/.project
          flex/sdk/trunk/frameworks/projects/rpc/.settings/
          flex/sdk/trunk/frameworks/projects/rpc/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/spark/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/spark/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/spark/.project
          flex/sdk/trunk/frameworks/projects/spark/.settings/
          flex/sdk/trunk/frameworks/projects/spark/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/sparkskins/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/sparkskins/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/sparkskins/.project
          flex/sdk/trunk/frameworks/projects/sparkskins/.settings/
          flex/sdk/trunk/frameworks/projects/sparkskins/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/textLayout/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/textLayout/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/textLayout/.project
          flex/sdk/trunk/frameworks/projects/textLayout/.settings/
          flex/sdk/trunk/frameworks/projects/textLayout/.settings/org.eclipse.core.resources.prefs
          flex/sdk/trunk/frameworks/projects/wireframe/.actionScriptProperties
          flex/sdk/trunk/frameworks/projects/wireframe/.flexLibProperties
          flex/sdk/trunk/frameworks/projects/wireframe/.project
          flex/sdk/trunk/frameworks/projects/wireframe/.settings/
          flex/sdk/trunk/frameworks/projects/wireframe/.settings/org.eclipse.core.resources.prefs
