1 Reply Latest reply on Nov 22, 2009 6:16 AM by chris.huston.t10
    Receive answer from the server?
    mh22gw Level 1
      I have made an app that sends mail from Flex. it's working and the mail is sent. I'm using "HTTPService", I have tried to use "lastResult" to receive an enswer from the server, this will not work. How can I do to receive an answer from the server?
      public
      function sendMail():void{
      if(txtName.text == "" || txtMail.text == "")
      Alert.show(
      "Du måste ange ditt namn.");
      else{
      srv.send();
      private function getResult(event:ResultEvent):void{
      Alert.show(event.message.toString());
      public function emailResult():void{
      Alert.show(
      "Ditt meddelande är skickat.");
      //this.submitBtn.enabled = false;
      public function faultHandler():void{
      Alert.show(srv.toString());
      <mx:HTTPService
      id="srv" url="http://www.mhwebb.se/swfcontact.aspx" method="POST"
      result="emailResult()" fault="faultHandler()"
      <mx:request>
      <name>
      {txtName.text}
      </name>
      <mail>
      {txtMail.text}
      </mail>
      <subject>
      {txtSubject.text}
      </subject>
      <mess>
      {txtMess.text}
      </mess>
      </mx:request>
      </mx:HTTPService>
      <mx:Form height="312" width="341" x="0">
      <mx:Panel x="10" y="10" width="308" height="276" layout="absolute" title="mhWebb FlexMail" backgroundColor="#FDFCD3">
      <mx:Label x="10" y="10" text="Ditt namn:" width="100"/>
      <mx:Label x="10" y="36" text="Din e-post:" width="100"/>
      <mx:Label x="10" y="62" text="Ämne:" width="100"/>
      <mx:Label x="10" y="88" text="Meddelande:" width="100"/>
      <mx:TextInput x="118" y="8" id="txtName"/>
      <mx:TextInput x="118" y="34" id="txtMail"/>
      <mx:TextInput x="118" y="64" id="txtSubject"/>
      <mx:TextArea x="118" y="94" id="txtMess" height="100"/>
      <mx:HBox x="10" y="202" width="268">
      <mx:Button label="Skicka" id="btnSend" click="sendMail()" fillAlphas="[1.0, 1.0, 0.3, 1.0]" fillColors="[#FFFFFF, #FFFFFF, #A6FAB0, #05CA1C]"/>
      <mx:Button label="Radera" id="btnDelete" fillAlphas="[1.0, 1.0, 0.3, 1.0]" fillColors="[#FFFFFF, #FFFFFF, #FBBABA, #FF0000]"/>
      </mx:HBox>
      </mx:Panel>
      </mx:Form>
        • 1. Re: Receive answer from the server?
          chris.huston.t10 Level 3
          Listen for the result event in a function rather than accessing the result directly in the lastResult. This will make it much easier to debug the returned result.
          <mx:HTTPService
          result="emailResult(event)" fault="faultHandler()"
          public function emailResult(event:ResutlEvent):void{
          trace(event.result); //Depending on your result, you may need to add the property field you want to access i.e. event.result.myMessage
          Alert.show(
          Chris
