5 Replies Latest reply on Nov 22, 2009 2:51 PM by Rothrock
    Easing a gotoAndStop(frame) given by the mouse position
    Pedromvpg
      Hi there.
      I have an external swf loaded into the background and i want it to go to a frame according to the mouse vertical position.
      Example: when the mouse is on the bottom part of the screen the movie is in the frame 0 and when it is on the top value goes to 800.
      so far i did it like this:
      _root.onEnterFrame = function ()
           var frame:Number = Stage.height-_ymouse;
           bgContainer.gotoAndStop(frame);
      But somehow i need it to ease between the values given by the mouse position so that when there is a fast movement of the mouse, the swf only gradually goes to the frame equivalent to the last mouse position.
      any sugestions??
      Cheers!
        • 1. Re: Easing a gotoAndStop(frame) given by the mouse position
          What is happening in these 800 frames?
          • 2. Re: Easing a gotoAndStop(frame) given by the mouse position
            Pedromvpg Level 1
            the end of the movie.. and the end of the stage
            what i can not figure out is how to convert the values of _ymouse into a more smooth movement that goes though all the frames.
            thanks
            • 3. Re: Easing a gotoAndStop(frame) given by the mouse position
              Rothrock Level 5
              You could just apply some basic easing:
              actualFrame+=Math.round((targetFrame-currentFrame)/dampFactor);
              clip.gotoAndStop(actualFrame);
              Where target frame is the frame that your _ymouse position tells you that you need to get to. The current frame is the frame you are actually on. And dampFactor is a number greater than 1 (can be fractional like 1.5 or 3.2).
              • 4. Re: Easing a gotoAndStop(frame) given by the mouse position
                Pedromvpg Level 1
                actualFrame ist not a number NaN so i can't use it to define a frame to the clip to stop..
                I just need a function that makes something like this:
                _ymouse           ---->            clip.gotoAndStop()
                     1                  ---->                     1
                     800              ---->                     16
                     800              ---->                     26
                     800              ---->                     67
                     800              ---->                     135
                     800              ---->                     233
                     800              ---->                     358
                     800              ---->                     498
                     800              ---->                     571
                     800              ---->                     704
                     800              ---->                     731
                     800              ---->                     800
                • 5. Re: Easing a gotoAndStop(frame) given by the mouse position
                  Rothrock Level 5
                  That is what I have given you. Not sure what you mean that actual frame is NaN. You will need to change it into your code. What I gave you isn't code, it is the algorithm/pseudo code for some generic easing. Something like this:
                  var frame:Number = Math.round((Stage.height -_ymouse - bgContainer_currentframe)/3);
                  bgContainer.gotoAndStop(bgContainer._currentframe+frame);
