7 Replies Latest reply on Nov 23, 2009 7:25 AM by Loic.Aigon
    ScriptUI : Check if shiftKeyPressed when clicking a button ?
    Loic.Aigon Adobe Community Professional
      Hello,
      I would like to know if I can control if the shift key is pressed when clicking on a button ?
      I saw :
      DrawState.shiftKeyPressed (Read Only)
      Data Type: boolean
      True if the Shift key is being pressed.
      But it's connected to :
      DrawState
      Describes an input state at the time of the triggering   ScriptUIGraphics.onDraw()  event.
      Contains properties that report whether the current control has the input focus, and the particular mouse button and keypress state. Passed in as argument to  ScriptUIGraphics.onDraw() .
      But I can't see how to connect my button click event and the shiftkeypressed control :-S ?
      Any hint ? TIA Loic
        • 1. Re: ScriptUI : Check if shiftKeyPressed when clicking a button ?
          Harbs. Level 6
          Hi Loic,
          Here's a basic skeleton (only works in CS4):
          uiElement.addEventListener( "keydown", handleShift  );
          function handleShift ( myEvent ) {
               if ( myEvent.shiftKey ) { // Shift key pressed down
                    isShiftPressed = true;
               else {
                    isShiftPressed = false;
          Harbs
          • 2. Re: ScriptUI : Check if shiftKeyPressed when clicking a button ?
            Awesome Harbs,
            Thanks for your help on that topic ;-)
            Bye Loic
            • 3. Re: ScriptUI : Check if shiftKeyPressed when clicking a button ?
              Oups too quick,
              I am trying hard to make it run but it behaves weirdly (on my fault)
              #targetengine session
              rapidDlg = new Window('window',"btn test", undefined);
              rapidDlg.btn = rapidDlg.add('button',undefined,'is shift pressed ?');
              rapidDlg.btn.onClick = function(){
                  pressed = rapidDlg.btn.addEventListener( "keydown", handleShift  );
                  alert(pressed);
                  rapidDlg.btn.removeEventListener( "keydown", handleShift  );
              rapidDlg.show();
                   else {
                  return isShiftPressed;
              alert(pressed) on the onClick callback sometimes throws false when true, sometimes sticks to true whatever shift is pressed or not...
              I must do something wrong but can't see where :-S
              Loic
              • 4. Re: ScriptUI : Check if shiftKeyPressed when clicking a button ?
                Dirk Becker Level 4
                rapidDlg.btn.addEventListener( "mousedown",function (myEvent) {
                myEvent.target.text = myEvent.shiftKey ? "Yes" : "No";
                rapidDlg.show();
                Dirk
                • 5. Re: ScriptUI : Check if shiftKeyPressed when clicking a button ?
                  Harbs. Level 6
                  Hi Loic,
                  Here's a more useful example. (It's one of the components in my Script UI libarary which mimics the behavior of InDesign's Integer edit boxes.) A big chunk of the code is based on the work of Bob Stucky. To use it you just do:
                  myIntegerEditbox = new HarbsUI.IntegerEditBox(myContainer[,props]);
                  All the props values are optional, and you can specify smallNudge and largeNudge values like in the standard InDesign widgets.
                       HarbsUI = {};
                       HarbsUI.IntegerEditBox = function(container,props){//width,editValue,minimumValue,maximumValue,largeNudge,smallNudge
                            var width = props.width || 50;
                            this.value = props.editValue || 0;
                            this.minimumValue = props.minimumValue || 0;
                            this.maximumValue = props.maximumValue || 100;
                            this.text = this.value;
                            var editBox = container.add("edittext", undefined, this.value );
                            this.largeNudge = props.largeNudge;
                            //alert(this.largeNudge);
                            this.smallNudge = props.smallNudge;
                            var that =this;
                            if(kAppVersion >=6){
                                 editBox.addEventListener( "keydown", handleNudge  );
                            editBox.preferredSize.width = width;
                            editBox.widget = this;
                            editBox.onChanging = function() {
                                 if ( this.text.length == 0 ) {
                                      //alert(2);
                                      this.text = this.widget.value;
                                      this.widget.text = this.text;
                                 else if ( isNaN( parseInt( this.text ) ) ) {
                                      this.text = this.widget.text
                                 else if ( parseInt( this.text ) > this.widget.maximumValue ) {
                                      this.text = this.widget.maximumValue;
                                 else if ( parseInt( this.text ) < this.widget.minimumValue ) {
                                      this.text = this.widget.minimumValue;
                                 else{
                                      this.text=parseInt(this.text);
                            function handleNudge ( myEvent ) {
                                 if ( myEvent.shiftKey ) { // then we're using the largeNudge
                                      var myNudge = that.largeNudge;
                                 else { // use the small nudge
                                      var myNudge = that.smallNudge;
                                 // handle the case of a blank entry in the field at the start
                                 if ( myEvent.target.text == "" ) {
                                      var myNum = 0;
                                 else {
                                      var myNum = parseFloat( myEvent.target.text );
                                 if(isNaN(myNum) ){myNum=0}
                                 switch( myEvent.keyName ) {
                                      case "Down" : { // just fall through with myNudge set to it's negative value
                                           myNudge = myNudge * -1;
                                      case "Up" : {
                                           //alert('up');
                                           myEvent.target.text = higherMultiple( myNum, myNudge, that.maximumValue, that.minimumValue );
                                           myEvent.target.nudged=true;
                                           break;
                       // this next function is to make sure the nudge feature increments in multiples of the nudge value, and handles the max/min value settings
                            function higherMultiple ( myNum, myNudge, max, min ) {
                            // The behavior of the InDesign's nudges is to go to the next multiple of the nudge value
                            // for example, if the control's value is 7, the largeNudge is 5, a large nudge will make the value 10 (next multiple of the largeNudge).
                                 if ( myNudge < 0 ) { // if the nudge is negative, we're incrementing down, but in the loop below, we're always counting up
                                      var myIncrement = -1;
                                 else {
                                      var myIncrement = 1;
                                 // here we have to catch the case of the values being at max or min, we can't increment if that's the case
                                 if ( max != undefined && ( myNum + myIncrement ) >= max ) { // if there's a max value, and incrementing goes past it, return
                                      return max;
                                 else if ( min != undefined && ( myNum + myIncrement ) <= min ) { // if there's a min value, and decrementing goes past it, return
                                      return min;
                                 for ( var i = 0; i < myNudge; i++ ) {
                                      myNum += myIncrement;
                                      if ( myNum % myNudge == 0 ) { // if we're at a multiple of the nudge value, return the number
                                           return myNum;
                                      else if ( max && myNum >= max ) { // if there's a max value, and we're at it, return
                                           return max;
                                      else if ( min && myNum <= min ) { // if there's a min value, and we're at it, return
                                           return min;
                                 return myNum;
                            return editBox;
                  Harbs
                  • 6. Re: ScriptUI : Check if shiftKeyPressed when clicking a button ?
                    Hi Harbs,
                    Thanks a lot for all your care and share,
                    The method you gave me works incredibly fine (mousedown). I will have a deeper look on your second proposal at rest ;-)
                    A great thank you to you !
                    Loic
                    • 7. Re: ScriptUI : Check if shiftKeyPressed when clicking a button ?
                      And A BIG BIG THANK YOU to Dick that I forget to thank
                      in the excitement ;-)
                      Loic
