11 Replies Latest reply on Dec 4, 2009 10:29 PM by dhishok
    get object reference to selection...
    dhishok Level 1
      Hi Everyone,
      I have generating art links report. I want to include page numbers along with the art link names.
      I getting page numbers through (itemLink.parent.parent.name). If the link has grouped with 1 or 2 or more groups then it is difficult for me to get the page numbers.
      Expecting better way from you people. Thanks in advance.
      Regards
      Thiyagu
        • 1. Re: get object reference to selection...
          Loic.Aigon Adobe Community Professional
          you may need to recurse the object while the parent isn't a page
          var theParent = itemLink.parent.parent;
          while(theParent.constructor.name!="Page")
               theParent= theParent.parent;
          alert(theParent.name);
          Loic
          • 2. Re: get object reference to selection...
            dhishok Level 1
            Hi Loic,
            Its working fine. Thanks for your good help.
            Thiyagu
            • 3. Re: get object reference to selection...
              dhishok Level 1
              Hi Loic,
              I have checked the syntax and came to know that, it doesn't give page number, when the image placed in achored frame. Because when we try to find parent for this anchored image, the loop going in such a way " itemLink / image / rectangle / character / ".
              Can you please look in to this and help me out. Me too checking in my side.
              Thiyagu
              • 4. Re: get object reference to selection...
                That should do the trick :
                var doc = app.activeDocument;
                var myPageInfo ="";
                var myLinks = doc.links;
                for(i=0; i<myLinks.length; i++)
                    thePage = myLinks[i].parent;
                    while(thePage.constructor.name!="Page")
                        if(thePage.constructor.name == "Character")
                            thePage = thePage.parentTextFrames[0].parent;
                        else
                            thePage = thePage.parent;
                    var msg = myLinks[i].name +" is located on page " +thePage.name;
                    myPageInfo+=msg;
                    if(i<myLinks.length-1)
                        myPageInfo+="\n";
                alert(myPageInfo);
                • 5. Re: get object reference to selection...
                  dhishok Level 1
                  Hi Loic,
                  Thanks lot its working fine. But the concern is when i try to write these report as .txt or .xls file. The report starts with undefined. I have checked in several ways and it can't be solved. Below is my complete script.
                  var data;
                  var Rpt;
                  var theParent;
                  try{
                      var myPath = myDoc.fullName + "";
                  catch(_){alert ("Save document and try again!");exit();}
                  myPath = myPath.replace(".indd",".txt");
                  var myFile = new File (myPath);
                  myFile.open ('w');
                  var g = app.activeDocument.links;
                  myCount=0;
                  for (i = 0; i < g.length; i++)
                          if ((g[i].parent.absoluteHorizontalScale!=100) || (g[i].parent.absoluteVerticalScale!=100))
                              theParent=g[i].parent;
                                  if (theParent.constructor.name=="Character")
                                      theParent=theParent.parentTextFrames[0].parent;
                                  else
                                      theParent=theParent.parent;
                              Rpt="\n"+g[i].name+"    "+g[i].parent.absoluteHorizontalScale+"%    "+g[i].parent.absoluteVerticalScale+"%    "+theParent.name;
                              data += Rpt;
                              myCount++;
                      else {continue;}
                  myFile.writeln (data);
                  myFile.close('w');
                  alert ( "The Scaling Report Generated for "+myCount+" Images." );
                  exit(0);
                  Can you please look into this help me out. Thanks in advance.
                  Thiyagu
                  • 6. Re: get object reference to selection...
                    First of all, declare the type of the data var. Inspite JS is loosely typed, data type var is not defined yet when you first try to add string to it. That's why you get the undefined.
                    Secondly, I usually add the carriage return at end of the loop with a condition based on the increment value. See the code...
                    Bye,
                    Loic
                    PS: Do you know that this kind of code has already been written dozen of times :-D ? Have a look on Indesign secrets (http://bit.ly/V7xBp) and FWIW you may have a look there two :-) :http://bit.ly/70EKUp
                    Regards, Loic
                    var data=''; //Declare data as an empty string
                    var Rpt;
                    var theParent;
                    try{
                    myFile.open ('w');
                    myCount=0;
                                    else
                                Rpt=g[i].name+"    "+g[i].parent.absoluteHorizontalScale+"%    "+g[i].parent.absoluteVerticalScale+"%    "+theParent.name;
                                data += Rpt;
                                if(i<g.length-1) //Adds a carriage return while i < length-1 meaning we are not at the last step of the loop
                                    data +="\n";
                                myCount++;
                        else {continue;}
                    myFile.close('w');
                    exit(0);
                    • 7. Re: get object reference to selection...
                      Dirk Becker  Level 4
                      Loic,
                      have a look this approach, instead of your counter.
                      It may even save another millisecond with the shorter intermediate strings.
                      Dirk
                      var data = []; // empty array
                      data.push("line1");
                      data.push("line2");
                      alert(data.join("\n"));
                      • 8. Re: get object reference to selection...
                        Hi Dirk and thanks for the input.
                        I will try it as soon as possible.
                        I am quite puzzled. I may understand array speed up the script but I can figure out when it has to bes used.
                        var data = []; // empty array (start of the script)
                        for links loop
                        data.push(i-1);
                        data.push(i);
                        data.join('\n')
                        is that so ?
                        Loic
                        • 9. Re: get object reference to selection...
                          Dirk Becker  Level 4
                          Almost right. Apparently I was a bit too dense, let's retry with comments:
                          // The strings are collected into the variable "strings", initialized to an empty array.
                          var strings = [];
                          // just some loop
                          for( i=1; i<=10; i++ ) {
                               // create one string
                               var str = "Line "+i;
                               // function Array.push() append the given string, modifying the array in place.
                               strings.push(str);
                          // combine the array entries into a string, with the given separator
                          var separator = "\n";
                          // the result is returned, the array itself is unchanged.
                          var data = strings.join(separator);
                          // output
                          alert(data);
                          • 10. Re: get object reference to selection...
                            Ok Dirk,
                            Thanks a lot for time passed  in the explanation ;-)
                            Loic
                            • 11. Re: get object reference to selection...
                              dhishok Level 1
                              Hi Loic / Dirk,
                              Now its clear for me. Thanks for your kind  support. The array concept also working fine.
                              Regards
                              Thiyagu
