4 Replies Latest reply on Nov 23, 2009 7:04 AM by Sorcery
    e4x filter
    Sorcery
      Hi
      I try to filter a xml file whit e4x function
        HttpServie whit  e4x format
      <mx:HTTPService id="catXml" url="data/data.xml" resultFormat="e4x"
      result="httpSResult_Handler(event)"
        Actionscript
      public var itemsTree:XMLList ;
      public function httpSResult_Handler(e:Event):void{
      itemsTree= catXml.lastResult.operatore;
      If i try to read normal xml it's ok, but if i try to filter it...
      itemsTree=catXml.lastResult.operatore.(settore == "3").toString();
      Error : "operatore" not defined??
      Thank's for help.
      xml file
      <root>
      <operatore>
      <nome>nome</nome>
      <cognome>cognome</cognome>
      <num_matricola>43</num_matricola>
      <settore>3</idtbl_operatore_settore>
      <settore2>0</idtbl_operatore_settore2>
      </operatore>
      <operatore>
      <nome>nome</nome>
      </operatore>
      </root>
        • 1. Re: e4x filter
          paul.williams Level 4
          The filter expression works fine for me in a standalone app (although your xml is invalid). Can you post the full error?
          • 2. Re: e4x filter
            chris.huston.t10 Level 3
            Your XML structure for the settore tags was not correct. You need to have a closing tag. The following works for me:
            <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" initialize="init()">
                <mx:Script>
                    <![CDATA[
                        private var catXml:XML = <root>
            <operatore>
            <nome>nome</nome>
            <settore>3</settore>
            <settore2>0</settore2>
            </operatore>
            <operatore>
            <nome>nome</nome>
            <settore>4</settore>
            </operatore>
            </root>;
                        private function init():void {
                            trace(catXml.operatore.(settore=="3").toString());
                </mx:Script>
            </mx:Application>
            I would also suggest using the ResultEvent rather than the lastResult property like this:
            public function httpSResult_Handler(e:ResultEvent):void{
            itemsTree=e.result.operatore.(settore == "3").toString();
            Chris
            • 3. Re: e4x filter
              RK... Level 3
              Hi, In your xml, settore and  settore2 don't have proper closing tags. Please try this
              <root>
              <operatore>
              <nome>nome</nome>
              </operatore>
              <operatore>
              <nome>nome</nome>
              <settore>2</settore>
              </operatore>
              </root>
              private function httpSResult_Handler(event: ResultEvent): void {
              var result: XMLList = (event.result as XML).*;
              var filterResult: XMLList = result.(settore == 3);
              Alert.show(filterResult.toXMLString());
              • 4. Re: e4x filter
                Sorcery Level 1
                Hi
                thank's for Help.
