24 Replies Latest reply on Dec 17, 2009 2:38 PM by Jill of all trades
    Images in multiserver environment
    Jill of all trades
      Will <cfimage source="#myImage#" action="writeToBrowser"> work in a multiserver/distributed environment where the webserver is separated from the application server by a firewall with no file services between them?
      Thank you.
        • 1. Re: Images in multiserver environment
          Jochem van Dieten Level 4
          Distributed is not a problem. Clustered may be a problem if you don't use sticky sessions.
          • 2. Re: Images in multiserver environment
            Jill of all trades Level 1
            Ok, well now I'm trying to install it...
            Web Server and App server - brand new OS setups
            VM ware both servers
            Windows 2008 64bit
            IIS 7 (with all the recommended changes:  ISAPI extensions and IIS 6 compatibility settings)
            IIS and Website set up in webserver.
            Coldfusion 9 64 bit
            Installing CF on app server - iis not installed on app server.
            When I get to the point where it asks me to add a web server/site, the drop down does not show IIS - just Apache and Sun.
            Needless to say, it won't let me go any further until I define a site.
            I'm stumped.
            Thanks for your help!
            • 3. Re: Images in multiserver environment
              Copy wsconfig.* from your CF server to your webserver and run it there. Then when it prompts, supply the hostname from the CF server.
              • 4. Re: Images in multiserver environment
                Say what??  I can't install CF so I can't copy anything, right?
                Are you saying run CF on the webserver?  Can't do that...
                • 5. Re: Images in multiserver environment
                  Install CF on the app server without connecting it to a web server, copy wsconfig to the webserver, run wsconfig from the webserver.
                  • 6. Re: Images in multiserver environment
                    It won't let me finish an install without adding a web server.
                    Sorry about the duplicate.  I noticed after I posted it that the original was for cfimage and I didn't expect to get my answer from that post.  The other area was a better place to get the answer I needed.  Not too happy to see it locked...
                    • 7. Re: Images in multiserver environment
                      Sure it will let you finish. Just select te builtin webserver.
                      • 8. Re: Images in multiserver environment
                        So this is the only way around this issue?
                        • 9. Re: Images in multiserver environment
                          does it matter where I copy wsconfig.* to??
                          • 12. Re: Images in multiserver environment
                            I got past the installing C++ runtime on the webserver so that I could run wsconfig. Now am faced with it not connecting to jrun/coldfusion server when I put in the app server ip.  I've done some searching and found most of these issues involving apache not IIS.  Any ideas?
                            Thanks!
                            • 13. Re: Images in multiserver environment
                              Try connecting manually to verify there are no firewalls blocking the traffic.
                              On the CF server, you have an admin console running on port 8300. So log on on the machine and go to http://localhost:8300/ Then log on to the administrator and check the prot numbers for all your instances (in the instance manager).
                              Then log on to the webserver and try to telnet to those ports from there. Does that work?
                              • 14. Re: Images in multiserver environment
                                Telnet was not really providing me with the answers I was looking for - but I was able to bring up the
                                CF admin on the web server.  Does that answer your question?
                                Thanks.
                                • 15. Re: Images in multiserver environment
                                  After I brought up the CF admin page in my brower on the webserver, I was able to find the app server in wsconfig.
                                  • 17. Re: Images in multiserver environment
                                    I wish...
                                    When I try to bring up a cfm page I get
                                    The service is unavailable.
                                    Server Error
                                    Either the Macromedia application server(s) are unreachable or none of them has a mapping to process this request.
                                    • 18. Re: Images in multiserver environment
                                      On your webserver, go to the appropriate subfolder under the wsconfig folder and in the .ini file enable verbose logging. Then shut down the webservice, remove the old log file and start the webservice and try again. If it still doesn't work, what does the logfile say?
                                      • 19. Re: Images in multiserver environment
                                        Thanks so much for your help!
                                        This is the log file - I replaced ip with 99.999:
                                        2009-12-04 13:14:00 jrISAPI[init:2328]  JRun 4.0 (Build 108795) JRun ISAPI Extension - Aug 28 2009 22:39:39
                                        2009-12-04 13:14:00 jrISAPI[init:2328]     Metrics is 0
                                        2009-12-04 13:14:00 jrISAPI[init:2328]     UseApiAlloc is 0
                                        2009-12-04 13:14:00 jrISAPI[init:2328]     BootStrap 99.999.78.97:51001
                                        2009-12-04 13:14:00 jrISAPI[init:2328]     serverstore D:/Jrun4/lib/wsconfig/1/jrunserver.store
                                        2009-12-04 13:14:00 jrISAPI[init:2328]     ignoresuffixmap 0
                                        2009-12-04 13:14:00 jrISAPI[init:2328]  Threads created: 25 - failed: 0
                                        2009-12-04 13:14:00 jrISAPI[init:2328]  JRun ISAPI Extension DLL Attaching
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  ***HttpExtensionProc for JRun ISAPI Extension: uri is "/viewlink/test.html"
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  trying to bootstrap from "99.999.78.97:51001"
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 initPool finished
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  initialized temp proxy for 99.999.78.97:51001
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97 jrConnect [656]
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  sent/avail/result 25/25/25
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  read/len/total 4/4/4
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  PROXY_GET_PROPS(clustered-servers) -> [656]
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  PROXY_PUT_PROPS <- [656]
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  read/len/total 125/125/125
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  clustered-servers: VLNKFCPWSIWEB01.sacmcm.adroot.bmogc.net_0=99.999.78.97:51001
                                        VLNKFCPWSIWEB01.sacmcm.adroot.bmogc.net_1=0:0:0:0:0:0:0:1:51001
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    VLNKFCPWSIWEB01.sacmcm.adroot.bmogc.net_0 = 99.999.78.97:51001
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    VLNKFCPWSIWEB01.sacmcm.adroot.bmogc.net_1 = 0:0:0:0:0:0:0:1:51001
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 returned socket [656] to pool
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97 jrConnect [672]
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  sent/avail/result 20/20/20
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  PROXY_GET_PROPS(server-props) -> [672]
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  PROXY_PUT_PROPS <- [672]
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  read/len/total 66/66/66
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    algorithm = ROUNDROBIN
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    weight = 1
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    mapcheck = 10
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    sticky = true
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    rep_id = 0e30
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 returned socket [672] to pool
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  mapcheck interval in secs: 10
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  proxy retry interval in secs: 600
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 socket timeouts (c15/r300/s15) secs
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  installed ROUNDROBIN load balancing algorithm.
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 sticky sessions: true
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 replication Id: 0e30 .
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  refreshing mappings for 99.999.78.97:51001
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 pooled socket [672] returned
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  sent/avail/result 24/24/24
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  PROXY_GET_PROPS(servlet-mappings) -> [672]
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  read/len/total 296/296/296
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    *.jst = jrun.jsp.JSTServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    *.jsp = jrun.jsp.JSPServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    /servlet/* = jrun.servlet.ServletInvoker
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  property =jmc-app.war has no value. skipping.
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    /server/* = jrunx.jmc.management.ServerCheckerServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    /services/* = org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    /JRunStatistics = jrun.jsp.JSPServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]    *.jws = org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  mapping converted from /servlet/* to /servlet*=jrun.servlet.ServletInvoker
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  mapping converted from /server/* to /server*=jrunx.jmc.management.ServerCheckerServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  mapping converted from /services/* to /services*=org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  installing new mappings for 99.999.78.97:51001 count: 7
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  old mappings count: 0
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  Mappings for 99.999.78.97:51001 will be refreshed every 10 seconds.
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  initialized proxy for 99.999.78.97:51001
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  addProxy - after
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]     /jrunstatistics=jrun.jsp.JSPServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]        99.999.78.97:51001 active: 1
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]     /services*=org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]     /servlet*=jrun.servlet.ServletInvoker
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]     /server*=jrunx.jmc.management.ServerCheckerServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]     *.jst=jrun.jsp.JSTServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]     *.jsp=jrun.jsp.JSPServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]     *.jws=org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 added/activated proxy, seq 0
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  Error in performing name resolution and creating ADDRINFO The specified class was not found.
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  initProxy failed to initialize socket pool
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  could not initialize proxy for 0:0:0:0:0:0:0:1:51001
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  0:0:0:0:0:0:0:1:51001 destroyed.
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  used proccess identity to open file D:/Jrun4/lib/wsconfig/1/jrunserver.store
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  persisted servers in D:/Jrun4/lib/wsconfig/1/jrunserver.store: proxyservers=
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 closing socket 656
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 destroying/closing socket [656] error 0
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  jrCloseSocket [656]
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  99.999.78.97:51001 destroyed.
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]     HTTP_HOST: 99.999.78.96
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  filtering /viewlink/test.html (/viewlink/test.html) HOST=99.999.78.96
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  filterRequest:   no match
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  ExecUrl: request received: URL=/viewlink/test.html
                                        2009-12-04 13:14:00 jrISAPI[6800:2328]  ExecUrl Completion: 404, ErrorCode=2, URL=/viewlink/test.html.
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  ***HttpExtensionProc for JRun ISAPI Extension: uri is "/viewlink/index.cfm"
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]     HTTP_HOST: 99.999.78.96
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  filtering /viewlink/index.cfm (/viewlink/index.cfm) HOST=99.999.78.96
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  refreshing mappings for 99.999.78.97:51001
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  99.999.78.97:51001 pooled socket [672] returned
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  sent/avail/result 24/24/24
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  read/len/total 4/4/4
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  PROXY_GET_PROPS(servlet-mappings) -> [672]
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  PROXY_PUT_PROPS <- [672]
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  read/len/total 296/296/296
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]    *.jst = jrun.jsp.JSTServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]    /server/* = jrunx.jmc.management.ServerCheckerServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]    *.jsp = jrun.jsp.JSPServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]    /servlet/* = jrun.servlet.ServletInvoker
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  property =jmc-app.war has no value. skipping.
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]    /services/* = org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]    /JRunStatistics = jrun.jsp.JSPServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]    *.jws = org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  99.999.78.97:51001 returned socket [672] to pool
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  mapping converted from /server/* to /server*=jrunx.jmc.management.ServerCheckerServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  mapping converted from /servlet/* to /servlet*=jrun.servlet.ServletInvoker
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  mapping converted from /services/* to /services*=org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  installing new mappings for 99.999.78.97:51001 count: 7
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  old mappings count: 7
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  Deleting old mappings...
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  updateProxy - after
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]     /jrunstatistics=jrun.jsp.JSPServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]        99.999.78.97:51001 active: 1
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]     /services*=org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]     /servlet*=jrun.servlet.ServletInvoker
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]     /server*=jrunx.jmc.management.ServerCheckerServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]     *.jst=jrun.jsp.JSTServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]     *.jsp=jrun.jsp.JSPServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]     *.jws=org.apache.axis.transport.http.AxisServlet
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  filterRequest:   no match
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  ExecUrl: request received: URL=/viewlink/index.cfm
                                        2009-12-04 13:14:15 jrISAPI[9488:2328]  ExecUrl Completion: 503, URL=/viewlink/index.cfm.
                                        • 20. Re: Images in multiserver environment
                                          On your ColdFusion server you have a file named web.xml in the WEB-INF folder. Does it have XML nodes named servlet-mapping with a *.cfm in them? In case you have multiple web.xml files, check the one that is in the ColdFusion server that listens to 99.999.78.97:51001.
                                          • 21. Re: Images in multiserver environment
                                            only one I found:  D:\JRun4\servers\cfusion\cfusion-ear\cfusion-war\WEB-INF\web.xml
                                            <servlet-mapping id="coldfusion_mapping_3">
                                            <servlet-name>CfmServlet</servlet-name>
                                            <url-pattern>*.cfm</url-pattern>
                                            </servlet-mapping>
                                            <servlet-mapping id="coldfusion_mapping_4">
                                            <servlet-name>CFCServlet</servlet-name>
                                            <url-pattern>*.cfc</url-pattern>
                                            </servlet-mapping>
                                            <servlet-mapping id="coldfusion_mapping_5">
                                            <url-pattern>*.cfml</url-pattern>
                                            </servlet-mapping>
                                            It's a real life mystery!
                                            Thanks!
                                            • 22. Re: Images in multiserver environment
                                              Jill of all trades wrote on 12/4/2009 9:47 PM:
                                              You can say that again. Even when I build a mock similar to yours I can
                                              not replicate the issue you have. Which command did you use to run wsconfig?
                                              • 23. Re: Images in multiserver environment
                                                Oh...  you would not believe, but maybe you would.
                                                I noticed the connector I created was jrun so I tried to remove it.  It would not remove.  I added another to the same IP address and made it a cfusion connector.  That did not help.  I tried to remove both but I couldn't.  Kinda figured it was a permissions issue but by that time it was so messed up I called CF support since I was supposed to be done with this a week ago.  Spent quite a bit of time with them and ended up just restoring the webserver to get rid of the connector and reinstalling CF with them.
                                                Now we are trying to run the wsconfig.jar on the webserver and getting the infamous side by side error.  So I installed the C++ runtime from the CF install and had our administrator try to run it and he got the same results.
                                                Also ran into a problem trying to download 64bit java from Sun.  It just would not let me do that since I was trying to do it from a 32bit pc.  Server of course is locked down.  CF support just had me use the 32 bit on the webserver.
                                                Thanks for helping me with this!
                                                • 24. Re: Images in multiserver environment
                                                  After the restore, I created the connector using the wsconfig as you suggested and it worked perfectly!  Between that and a tweak to point CF to using another folder for the website documents, I was up and running!
                                                  To summarize:
                                                  1. Installed on the webserver the C++ redistributable package(only) from the Coldfusion install exe
                                                  2. created jrun4 folder on webserver
                                                  3. copied jrun4\bin \lib and \jre to webserver\jrun4
                                                  4. clicked jrun2\bin\wsconfig.exe
                                                  5. entered ip address of app server
                                                  6. changed admin to cfusion for type (this is where I went wrong before)
                                                  7. select the website
                                                  8. Clicked Configure web server for ColdFusion 9 applications option
                                                  low and behold I had a connector!
                                                  Also, the firewall is not up but we are passing images in memory between app and web server worked beautifully!
                                                  Thanks for your advice and help!
