4 Replies Latest reply on Nov 23, 2009 10:06 AM by Rothrock
    Simple Actionscript Help - Keypress
    neal2000uk Level 1
      Hello
      I am VERY new to Flash, so please excuse me if this seems very simple but all I am trying to achieve is to press a keyboard button to jump to the next frame.I have a button symobl off the stage and i am putting my code into that.
      I can get it to jump to the next frame using the following code:
      on (keyPress "<Left>") {
          gotoAndPlay(2);
      but instead of the left key i want to press 'R' in order for it to jump to frame 2. I've tried using the code:
      on (keyPress "r") {
          gotoAndPlay(2);
      but this does nothing. Can anyone tell me what the correct syntax to use is.
        • 1. Re: Simple Actionscript Help - Keypress
          If you're just learning, now is as good as time as any to learn to avoid placing code "on" objects.  You can use a Key listener instead of having a button carry the load.  Put the following code in the timeline on an actions layer...
          var keyListener:Object = new Object();
          Key.addListener(keyListener);
          keyListener.onKeyUp = function(){
                // trace(Key.getCode()); // use this to determine which key is which code
                if(Key.getCode() == 37){  // key LEFT
                      trace("clicked LEFT");
          When testing in Flash, in the Flash Player you should go to the Control option in the player menubar and select the option to disable keyboard shortcuts.  Otherwise, using most keys will not work because they are associated with shortcuts.
          • 2. Re: Simple Actionscript Help - Keypress
            neal2000uk Level 1
            Thank a lot, that worked perfectly
            • 3. Re: Simple Actionscript Help - Keypress
              You're welcome.  I should have extended my example a little bit, but hopefully you realize that the function can be used for all of the keys, just test for them...
                    } else if(Key.getCode() == 82){  // key "r"
                          trace("clicked r");
                    } etc...
              • 4. Re: Simple Actionscript Help - Keypress
                Rothrock Level 5
                Since you are new to Actionscript I would suggest that you not learn the "wrong" way to do things. Using on(event) handlers went out of style with Flash upon the introduction of Flash 6 in 2001. They have stubbornly held on, but have been removed when publishing for ActionScript 3. So don't put code directly on objects. Put it on the timeline. Here is a good tutorial about it.
                http://www.quip.net/blog/2006/flash/museum-pieces-on-and-onclipevent
                If you don't have many plans to keep working with Actionscript then learning AS2 is just fine, but if you want to go a long ways with Flash in the future I would recommend learning AS3.
                But here is the AS2 for what you are talking about:
                function onKeyDown() {
                if (Key.getCode() == ("R").charCodeAt(0)) {
                  gotoAndPlay(2);
                  Key.removeListener(this);
                Key.addListener(this);
                Select the first keyframe of your timeline. Make sure you don't have any buttons or movieclips selected and open the actionscript window. Make sure it says Actionscript-Frame at the top.
                This code doesn't care if it is "R" or "r" but that could be changed if it is important to you.
