6 Replies Latest reply on Nov 24, 2009 8:31 AM by plarts
    decode UTF-8 to ISO-8859-1
    plarts Level 1
      I am using the Google Maps API, it return in utf-8,
      so for some countries, caracters are wrong,
      My server is ISO-8859-1
      So, how to convert the result from utf-8 to iso-8859-1 ?
      I tried :
      <cfprocessingdirective pageEncoding="UTF-8">
      <cfcontent type="text/html; charset=UTF-8">
      <cfset setEncoding("URL", "UTF-8")>
      <cfset setEncoding("FORM", "UTF-8")>
      and
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      No change. always the wrong caracters,
      Thanks for any help with this mess.
      Pierre.
        • 1. Re: decode UTF-8 to ISO-8859-1
          Jochem van Dieten Level 4
          But your ColdFusion is not necessarily using the same charset as your server.
          Which version of CF are you using? If you are using CF 5 or older, forget it. If later, it should work out of the box if you use the appropriate charset attributes everywhere. Can you explain a bit more about the processing code?
          • 2. Re: decode UTF-8 to ISO-8859-1
            injun [576871] Level 1
            Hi!
            Try this trick:
            <cfsript>
            s="your_text";
            chr_current="your_current_charset";
            chr_new="your_new_charset";
            c=createobject("java", "java.lang.String").init(s);
            convstring=createobject("java", "java.lang.String").init(c.getbytes(chr_current),chr_new).tostring();
            </cfscript>
            • 3. Re: decode UTF-8 to ISO-8859-1
              plarts Level 1
              I am using CF v7.
              My server and CF are ISO-8859-1.
              But I am using Google Maps API , which returns country names in UTF-8.
              I tried the Google Maps directives, with adding parameter eo=ISO-8859-1 in the Google Key <script>,
              same result.
              Then  I have to convert to ISO-8859-1 , at least in that page for country names.
              (I have a specific problem with Thailande, Google Maps returns :  Tha๏lande
              and in the data base it writes : tha&#3663 ;lande   (an Access database)
              I answer to injun [576871]  ,
              Diificult to insert that code, because I am in a JavaScript code already.
              So it will not accept <cfscript> again inside ? I will try.
              Thanks for any help.
              Pierre.
              • 4. Re: decode UTF-8 to ISO-8859-1
                plarts Level 1
                Thanks, I will try at end of day,
                I have a meeting right now.
                Regard, Pierre.
                Pl-Art - Pierre LARDE
                http://www.pl-arts.com
                Email : pierre@pl-arts.com
                Tel : 04 93 60 48 91
                Auberge de la Clue, 06850, St Auban
                • 5. Re: decode UTF-8 to ISO-8859-1
                  plarts Level 1
                  I tried it before the insert Query,
                  But I get the same value :
                  Before : Tha๏lande
                  After : Tha๏lande
                  here is the code :
                  What do you think of ?
                  Thanks for all.
                  Pierre.
                  • 6. Re: decode UTF-8 to ISO-8859-1
                    plarts Level 1
                    I answered by mail, and the code has not appeared
                    here is the code used :
                    <cfoutput>
                    before : #form.pays#<br>
                    <cfscript>
                    s="#form.pays#";
                    chr_current="utf-8";
                    chr_new="ISO-8859-1";
                    c=createobject("java", "java.lang.String").init(s); convstring=createobject("java", "java.lang.String").init(c.getbytes(chr_current),chr_new).tostring();
                    </cfscript>
                    after : #convstring#<br>
                    </cfoutput>
                    Pierre.
