3 Replies Latest reply on Nov 27, 2009 4:50 AM by RK...
    Looping through an arrayCollection
    dgwillia1982
      I need to:
      1. loop through an array collection,
      2. select a specific string from that collection
      3. extract a url from that string
      4. insert an additional string to the array with that extracted url
      The code I am using so far is:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" minWidth="1024" minHeight="768">
          <mx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.rpc.events.ResultEvent;
                  [Bindable]
                  private var resultArrayCollection:ArrayCollection;
                  private function doSearch (e:MouseEvent):void
                      twitterSearch.url = "http://search.twitter.com/search.atom?q=LDN";
                      twitterSearch.send();
                  private function onResult (e:ResultEvent):void
                      resultArrayCollection = e.result.feed.entry as ArrayCollection;
          </mx:Script>
          <mx:HTTPService id = "twitterSearch"
                          result="onResult(event)" />
      the HTTP service pulls in data from Twitter search for example http://search.twitter.com/search.atom?q=LDN.
      All help would be greatfully received.
        • 1. Re: Looping through an arrayCollection
          ShankarFlex3 Level 2
          Hi
          I use this method to find objects in an ArrayCollection, you could probably modify accordingly.
          public function findObjInArry(arryRef:ArrayCollection, objId:int):Object
                   if(arryRef.length == 0)
                       return null;
                   for(var i:int=0; i<arryRef.length; i++)
                       var arryObj:Obejct = arryRef.getItemAt(i) as Object;
                       if(objId == arryObj.id)
                           return arryObj;
                   return null;
          Regarding adding items to ArrayCollection you can use the addItem methods.
          • 2. Re: Looping through an arrayCollection
            dgwillia1982 Level 1
            I really need something like this, but this throws an error:
                for(var count:int = 0; count < resultArrayCollection.length; count++)
                                trace(resultArrayCollection"[count]".title);
            • 3. Re: Looping through an arrayCollection
              RK... Level 3
              Please remove the double quotes -- "[count]"
              for(var count:int = 0; count < resultArrayCollection.length; count++) {
                   trace(resultArrayCollection[count].title);
