Revision: 12120
Revision: 12120
Author: aharui@adobe.com
Date: 2009-11-23 13:19:13 -0800 (Mon, 23 Nov 2009)
Log Message:
Change hacks in ButtonBar that force every renderer to update. Suppress selectedIndex adjustment in ButtonBarBase if the dataProvider is a ViewStack
QE Notes: Some Mustella test will fail because there is a bug in the test media that is now exposed because we cleaned up the way we adjust selectedIndex. ButtonBar/SWFs/Assets/TestComp.mxml does not add newVS to the display list (and should)
Doc Notes: None
Bugs: SDK-24087
Reviewer: Ryan
API Change: No
Is noteworthy for integration: No
tests: checkintests mustella/gumbo/components/ButtonBar
Ticket Links:
http://bugs.adobe.com/jira/browse/SDK-24087
Modified Paths:
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/ButtonBar.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ButtonBarBase.as
flex/sdk/trunk/frameworks/projects/spark/src/spark/components/supportClasses/ListBase.as
