0 Replies Latest reply on Nov 23, 2009 1:55 PM by Peter Farland
    [svn:fx-trunk] 12121: Integrating FXGUtils fixes from changlelist 636625:
    Peter Farland Level 3
      Revision: 12121
      Revision: 12121
      Author:   pfarland@adobe.com
      Date:     2009-11-23 13:55:27 -0800 (Mon, 23 Nov 2009)
      Log Message:
      - 2483956 (RadialGradientStrokes render differently between MXMLC runtime graphics and FXGUtils when there are default and some explicit parameters specified)
      - 2483947 (The default Radial Gradient Stroke renders differently between runtime MXML and FXGUtils)
      - 2480946 (FXGUtils doesn't correctly handle specification of explicit params of ScaleY and spreadMethod in conjunction with other defaults)
      - 2483730 (Clipping doesn't appear to work correctly when the transformation is specified as a matrix.)
      - 2481219 (FXGUtils doesn't correctly apply an elliptical clipping mask on a BitmapImage)
      - 2481170 (A path with a default fillMode of  scale does not  fully fill the enclosing path)
      - 2482234: Failures seen in MXMLC static compilation when fontFamily has been defined within  tag.
      QE notes: Yes, please investigate 1 mustella failure and 13 mxmlcunit failures from changes in error messages.
      Doc notes: N/A
      Bugs: N/A
      Reviewer: Sujata, Min
      Tests run: Checkintests, mustella fxg, mxmlcunit fxg
      Is noteworthy for integration: Yes
      Modified Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_en.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGVersion.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/dom/FXGNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/swf/FXG2SWFTranscoder.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/AbstractFXGNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/BitmapGraphicNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/DefinitionNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/EllipseNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GradientEntryNode.jav a
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicContentNode.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GraphicNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GroupDefinitionNode.j ava
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/GroupNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/LineNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/RectNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/RichTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/TextGraphicNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/BitmapFillNode. java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/LinearGradientF illNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/RadialGradientF illNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/fills/SolidColorFillN ode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/BevelFilterNo de.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/BlurFilterNod e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/ColorMatrixFi lterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/DropShadowFil terNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/GlowFilterNod e.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/GradientBevel FilterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/filters/GradientGlowF ilterNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich BlockTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich ParagraphNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/AbstractRich TextLeafNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/richtext/ImgNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/AbstractStrok eNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/LinearGradien tStrokeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/RadialGradien tStrokeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/strokes/SolidColorStr okeNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/AbstractCharacte rTextNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/text/ParagraphNode.ja va
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/transforms/ColorTrans formNode.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/transforms/MatrixNode .java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/sax/FXGSAXScanner.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ImageHelper.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/ShapeHelper.java
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/swf/TypeHelper.java
      Added Paths:
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/internal/fxg/dom/DOMParserHelper.java
