2 Replies Latest reply on Nov 30, 2009 12:51 PM by cyber0897
    datagrid/list item saperator need help
    cyber0897 Level 1
      hey guys.... so i got another question lol
      im trying for a list to look exactly like the image i have attached to this post...
      basically space between each item and a dotted line image on the bottom of that image....
      anyone have any ideas??
      i have the following so far...
          <mx:TabNavigator width="275" height="400">
              <mx:VBox label="USER OPTIONS" width="100%" height="100%">
                  <s:List width="100%" height="100%">
                              <fx:Object label="Adjust Volume" />
                              <fx:Object label="Arm/Disarm System" />
                              <fx:Object label="Change Mastercode" />
                              <fx:Object label="Secondary Codes" />
                              <fx:Object label="Bypass the Sensors" />
                              <fx:Object label="Record/Delete Messages" />
                              <fx:Object label="Set Time" />
                              <fx:Object label="System Status" />
              <mx:VBox label="TROUBLESHOOTING">
        • 1. Re: datagrid/list item saperator need help
          Peter deHaan Level 4
          I'd look at making a custom item rendererer and then adding a repeating fill BitmapImage at the bottom (or top):
          <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
              <s:Label id="labelDisplay"
                       left="4" right="4" top="4" bottom="5" />
              <s:BitmapImage id="dottedLine"
                             bottom="0" />
          And then set the item rederer in your main app:
                  <s:VerticalLayout paddingLeft="20" paddingTop="20" />
                  <s:HSlider id="sl" minimum="20" maximum="600" value="100" />
              <s:List id="lst" itemRenderer="skins.foo" labelField="firstName" width="{sl.value}">
                          <fx:Object firstName="1.One" lastName="1.Two" />
                          <fx:Object firstName="2.One" lastName="2.Two" />
                          <fx:Object firstName="3.One" lastName="3.Two" />
                          <fx:Object firstName="4.One" lastName="4.Two" />
                          <fx:Object firstName="5.One" lastName="5.Two" />
                          <fx:Object firstName="6.One" lastName="6.Two" />
                          <fx:Object firstName="7.One" lastName="7.Two" />
          • 2. Re: datagrid/list item saperator need help
            cyber0897 Level 1
            hey peter, thanks for the reply... i did something similar to that, and it works now...
