0 Replies Latest reply on Nov 23, 2009 6:25 PM by Peter Farland
    [svn:fx-trunk] 12133: Preserving whitespace for Spark text components and text-related child tags .
    Peter Farland Level 3
      Revision: 12133
      Revision: 12133
      Author:   pfarland@adobe.com
      Date:     2009-11-23 18:25:03 -0800 (Mon, 23 Nov 2009)
      Log Message:
      Preserving whitespace for Spark text components and text-related child tags. Whitespace that appears inside a text component but outside of text-related children should be ignored. The presence of any non-text related child tag removes whitespace at that level to avoid multiple-initializer errors for values.
      Note: This change is a work around for now as the MXML compiler wasn't setup to customize whitespace handling on a per-component basis. Longer term we need a way for components to opt in, perhaps via a manifest entry.
      QE notes: Please look out for testcases that now have whitespace preserved around text content.
      Doc notes: N/A
      Bugs:
      SDK-22601 - Spaces surrounded by  don't appear at runtime
      SDK-23160 - XML whitespace removal breaks TextFlow's whiteSpaceCollapse="preserve" setting
      SDK-24341 - Inconsistent word spacing results between MXMLC static and runtime compilation
      Reviewer: Paul
      Tests run: checkintests
      Is noteworthy for integration: Yes
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22601
          http://bugs.adobe.com/jira/browse/SDK-23160
          http://bugs.adobe.com/jira/browse/SDK-24341
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/Grammar.jj
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/CDATANode.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/MxmlScanner.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/mxml/dom/Node.java
