3 Replies Latest reply on Nov 24, 2009 4:43 AM by John Joslin
    ACR doesn't install in PS4 under Snow Leopard.
    moochdog2201 Level 1
      PS 4.  Mac OS 10.6.  Application migrated from old power pc mac to new intel mac.  ACR doesn't work even though a repeated install yields a message that says it is already present.  Where does this file reside?  I can't find it in Finder.  In the old mac it was in plug-ins.  Anyone else experience this issue?  Thanks.
        • 1. Re: ACR doesn't install in PS4 under Snow Leopard.
          John Joslin Level 6
          Do you really mean PS4? Or is it CS4?
          What does it say in Helps About plug-in under ACR?
          Try this from the Adobe download page:
          Installation Instructions
          To open a DMG file:
          Double-click the file. This will open Disk Copy, which mounts the image on your desktop.
          To install with Adobe Creative Suite 4 or Photoshop CS4:
          Automated installation on Mac or Windows®:
          1. Select Updates... from the Help menu
          2. Follow the on-screen dialogs to download and install the latest available Camera Raw update
          Manual installation on Mac:
          1. Exit Photoshop CS4 and Adobe Bridge.
          2. Open the download file and double-click Setup, and follow the on-screen instructions.
          3. Launch Photoshop CS4 or Adobe Bridge.
          • 2. Re: ACR doesn't install in PS4 under Snow Leopard.
            Thanks for the reply.  I already followed all those steps and there is
            nothing int he knowledge base about this problem.  I am using
            photoshop 4 but is is not part of the creative suite.
            moochdog2291
            • 3. Re: ACR doesn't install in PS4 under Snow Leopard.
              John Joslin Level 6
              It's called Photoshop CS4 – even if it's a stand-alone installation (look at the splash screen).
              The path is described here in Adobe's instructions for a manual install:
              "Drag the Camera Raw.plugin file from the Camera_Raw_5_5 disk image into /Library/Application Support/Adobe/Plug-Ins/CS4/File Formats. If you are prompted to overwrite or replace the existing plug-in file, then click Replace.
              Note: This file path refers to the Library folder at the root level of the startup disk volume, not the Library folder inside a user's Home folder."
