5 Replies Latest reply on Nov 24, 2009 6:13 PM by RotoRouter
    How do I merge to layers to only cut the edges? with two colors?
      The attached file is a pdf file. It’s for a vinyl printer cutter. The problem I’m having is that I need to be able to apply a contour-cut swatch in illustrator to only cut out the edges of the lettering (essentially cut out the white) but right now the only way I can select the edges is to select the either the black letters or gold shadow, which runs my cut swatch through the letter or shadow….causing the letters to get cut up on the cutter where the black and gold intersect. I need to be able to apply the cut swatch to only the exterior edges and the white center areas of the letters. If this makes sense and you know how it works, please let me know. Thanks!!
