17 Replies Latest reply on Nov 27, 2009 12:53 PM by BKBK
    How to improve CFC performance
    mjoshi Level 1
      Hi All,
      The database queries I had at the top of the page were moved into a CFC and now it is taking noticeable amount of time in displaying the data. How do I improve the performance of the CFC so that it does not take more amount of time for displaying the data.
      I'm on CF 9 Standard version and the methods in the CFC return queries to the page that invoke the component.
      Please help. Thanks.
      - Milind
        • 1. Re: How to improve CFC performance
          Adam Cameron. Level 5
          Can you show us some "before" and "after" code?
          Adam
          • 2. Re: How to improve CFC performance
            mjoshi Level 1
            Adam,
            Its the same queries that I had on the page are now in a CFC. Do you still need the SQLs? There is absolutely no change in the queries.
            Thanks.
            - Milind
            • 3. Re: How to improve CFC performance
              Dan Bracuk Level 5
              Why did you move the queries?  Is it so they are available to other pages, or did you do it for philisophical reasons?
              • 4. Re: How to improve CFC performance
                mjoshi Level 1
                Yes, I moved them to a CFC so that the same queries can be made available to other pages. But, I was surprised to see the performance taking a hit.
                Thanks.
                - Milind
                • 5. Re: How to improve CFC performance
                  Dan Bracuk Level 5
                  CFCs do come with a bit of a performance price.  How big a hit are you seeing?
                  • 6. Re: How to improve CFC performance
                    Well if the SQL is identical then no need to post it.  But everything else in the CFC and the calling code would help.
                    Adam
                    • 7. Re: How to improve CFC performance
                      mjoshi Level 1
                      Okay ... here we go
                      This is how I invoke the CFC:
                      <cfinvoke component="dbqueries.iriqueries" method="getRunDetails" returnvariable="qryRunDetails">
                           <cfinvokeargument name="projid" value="#trim(url.pid)#">
                           <cfinvokeargument name="runid" value="#trim(url.rid)#">
                           <cfinvokeargument name="cru" value="#trim(url.cru)#">
                      </cfinvoke>
                      <cfif IsQuery(qryRunDetails)>
                           <!--- Data display processing --->
                      <cfelse>
                           <!--- Error message processing --->
                      </cfif>
                      And the CFC has following code (I have modified the column names and table names):
                      <cffunction name="getRunDetails" returntype="query" output="no">
                           <cfargument name="projid" type="string" required="yes">
                           <cfargument name="runid" type="string" required="yes">
                           <cfargument name="cru" type="string" required="yes">
                           <cfset var qryRunDetails = "">
                           <cftry>
                                <cfquery datasource="#mrsdsn#" name="qryRunDetails">
                                SELECT col1, col2, col3, col4, col5
                                FROM my_table_name
                                WHERE trim(pcn) = <cfqueryparam cfsqltype="cf_sql_varchar" maxlength="13" value="#trim(arguments.projid)#">
                                AND trim(run_id) = <cfqueryparam cfsqltype="cf_sql_varchar" maxlength="20" value="#trim(arguments.runid)#">
                                AND trim(cru) = <cfqueryparam cfsqltype="cf_sql_varchar" maxlength="20" value="#trim(arguments.
                      cru)#">
                                AND col9 is null
                                ORDER BY
                      col1 ASC
                                </cfquery>
                                <cfcatch type="database"><cfset bError = true></cfcatch>
                           </cftry>
                           <cfreturn qryRunDetails>
                      </cffunction>
                      Note that variables bError and mrsdsn has been declared at the component level not at the method level.
                      • 8. Re: How to improve CFC performance
                        OK, so not really "displaying" the data in the CFC method: just fetching it.  I don't see anything suboptimal in your code, anyhow.  It's always good to put a second set of eyes on these things though.
                        As Dan said there is a bit of an overhead instantiating a CFC, but it should be marginal compared to running a DB query.
                        Can you split your CFC instantiation from your method call and time both separately to see how much overhead the CFC instantiation is actually adding?
                        Oh, and is "dbqueries.iriqueries" the full path to the CFC from the webroot, or is it relative to your current template or a custom tag path?  I guess the question is does CF have to hunt around for the CFC, or is that its explicit path?  What'd the relevant dir structure, and where are any mappings or custom tag paths pointing?
                        Adam
                        • 9. Re: How to improve CFC performance
                          mjoshi Level 1
                          Adam -
                          1. How do I separate the instantiation of CFC from method call? Can you provide help?
                          2. "dbqueries" is the directory directly under "<cfroot>\CustomTags\". So, I do not think CF would take time in trying to locate the iriqueries.cfc file.
                          Is there a properties and/or xml file that I can read in order to find out what directories CF looks?
                          Thanks for taking time in helping me.
                          - Milind
                          • 10. Re: How to improve CFC performance
                            You can create an object instance with createObject(): http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WSc3ff6d0ea77859461172e0811cbec22c24-69 7b.html
                            And then you can call its methods as per the example in the docs.  It's a bit less clunky than <cfinvoke> IMO.
                            There's something in the docs about which order CF looks for things in, but I suspect on custom tag paths is going to be one of the last places (found the page: http://help.adobe.com/en_US/ColdFusion/9.0/Developing/WSc3ff6d0ea77859461172e0811cbec22c24 -7e17.html).
                            Whilst testing, move your CFC into the same dir structure as your calling code, and see if that improves things.  I gotta say I always explicitly path my CFCs, eg: com.mydomain.myapp.somepackage.someCfc, where /com is a CF mapping.  That said... I would not expect this to reflect much of a performance hit / improvement.
                            Adam
                            • 11. Re: How to improve CFC performance
                              Dan Bracuk Level 5
                              This thread might be relevent.
                              http://forums.adobe.com/thread/529289?tstart=0
                              Also, to see where the delay is occurring, cfdumping a gettickcount() right before your cfinvoke tag and at various places in the cfc may provide some useful information.
                              • 12. Re: How to improve CFC performance
                                BKBK Adobe Community Professional & MVP
                                Milind,
                                Did you turn debugging on? Coldfusion's debugging apparatus parses and records some administration about all the files involved in a request, from the Application.cfc events fired, through to the objects instantiated and methods invoked.
                                In general, with debugging on, the CFC will contribute much more to the debugger's consumption than an ordinary CFM page. To compare like with like, switch debugging off before doing any comparison. You may likely find there is nothing wrong with your CFC's performance.
                                • 13. Re: How to improve CFC performance
                                  Abinidi Level 1
                                  Just a long shot from prior experience:
                                  Does  "dbqueries." happen to be a mapping set in CF administrator? I have seen a few times, random, that when its' a mapping, it is a bit slower rather than letting it parse the file/folder path of the webroot. I never could figure it out, but once I had this issue, 2-4 sec difference by having the CF mapping.
                                  • 14. Re: How to improve CFC performance
                                    mjoshi Level 1
                                    No. The debugging is not turned on.
                                    • 15. Re: How to improve CFC performance
                                      mjoshi Level 1
                                      No "dbqueries" is not mapped. Its a physical directory under "<cfroot>\CustomTags\".
                                      • 16. Re: How to improve CFC performance
                                        Then turn it on in the Coldfusion Administration. It will display the processes involved in a request and their execution times.
                                        • 17. Re: How to improve CFC performance
                                          Does this perform any better?
                                          <cfset qryRunDetails = createobject("component", "dbqueries.iriqueries").getRunDetails(trim(url.pid),trim(url.rid),trim(url.cru))>
