3 Replies Latest reply on Nov 24, 2009 6:22 AM by Loic.Aigon
    launch a jar executable
    nicola.pulvirenti
      Hi all,
      I'm developing a javascript for ID CS3 (5.0.4) and I need to launch a java executable (.jar) as if it was double-clicked.
      I do this on OSX platforms and it works fine:
      var oJavaApp = new File("/path/to/myjava/folder/myJar.jar");
      var result=oJavaApp.execute();
      ...and I tried with a batch file:
      var oMyBat = new File("/path/to/myjava/folder/launchMyJar.bat");
      var result=oMyBat.execute();
      but no way to make it work on Windows XP
      ...Yes, I even used the win path c:\\path\\to\\myjava\\folder\\myJar.jar
      When I double-click either on myJar.jar or on launchMyJar.bat all works fine.
      Is there a way to launch that jar from an ID script?
      Thanks in advance.
      Nicola.
        • 1. Re: launch a jar executable
          Loic.Aigon Adobe Community Professional
          I can't tell you if it's related to XP environment but what I can say is that your windows path doesn't look good:
          You may use :
          "C:/xxx/yyyy/zzz" or "/c/xxx/yyyy/zzz" but I don't think "C:\\xxx\yyy\zzz" is correct.
          Try this and let us know.
          Regards,
          Loic
          • 2. Re: launch a jar executable
            nicola.pulvirenti Level 1
            SOLVED!!!
            Thanks Loic for your answer.
            Anyway, it wasn't a path problem (even the Windows-style path works).
            I discovered that vbs does launch jar files and js doesn't.
            So I created a vbs script (let's say javaLauncher.vbs):
            Dim oShell, oCurDir
            Set oShell = CreateObject("Wscript.shell")
            strPath = Wscript.ScriptFullName
            Set oCurDir = CreateObject("Scripting.FileSystemObject")
            Set objFile = oCurDir.GetFile(strPath)
            strFolder = oCurDir.GetParentFolderName(objFile)
            oShell.CurrentDirectory = strFolder
            oShell.Run "myJar.jar"
            Set oShell = Nothing
            and I call it from inside my javascript:
            oJavaApp = new File("c:\path\to\myfolder\javaLauncher.vbs");
            oJavaApp.execute();
            ...and that works!
            • 3. Re: launch a jar executable
              Nice ;-)
              May you have a look on a script I wrote that allow you to write and test code (whatever JS, VB or Applescript) inside of Indesign ?
              http://bit.ly/1iDPKJ
