2 Replies Latest reply on Nov 25, 2009 3:57 PM by Nyein Aung
    Script for Auto Date + 30 days
    Nyein Aung
      My company sends out date sensitive sales letters to our club members.
      Example: Today is dd/mm/yy, buy this product before dd/mm/yy and get $100 off.
      All these letters were designed in indesign CS4 and exported as PDFs (and than modified with form fields) so the company staff can edit the dates and print them as they wish.
      Is there a way to make it so when they load the document, one date is automatically changed to "today's" date and the rest of the date fields are automatically changed to the date of 30 days later?
        • 1. Re: Script for Auto Date + 30 days
          You will need to use JavaScript programing to create a document level script and custom calculation.
          You can set the date of a field upon opening a PDF by using a document level JavaScript:
          // define the value for the date field
          var sField = 'myDateFieldName';
          // define the format of the date string
          var cFormatDate = 'mm/dd/yyyy';
          // get the field object to update
          var TodayDate = this.getField(sField);
          // get the date object
          var oDate = new Date();
          // set the field's value to the formatted date
          TodayDate.value = util.printd(cFormatDate,  oDate);
          To add 30 days to a date you need to do all the math in milliseconds and use a custom calculation field
          // define some time constants
          var fSecond = 1000; // number of milliseconds in one second
          var fMinute = 60 * fSecond; // number of milliseconds in a minute
          var fHour = 60 * fMinute; // number of milliseconds in an hour
          var fDay = 24 * fHour; //number of milliseconds in a day
          // get the field object's string value
          var fTodayDate = this.getField(sField).value;
          // convert the string value into a date object
          var oDate = util.scand(cFormatDate, fTodayDate);
          // convert the date object to a value in milliseconds
          var fDate = oDate.getTime();
          // add 30 days to value using the number of milliseconds in a day
          var fNewDate = fDate + (30 * fDay);
          // convert computed date value to date object
          var oNewDate = new Date(fNewDate);
          // set the field's value to the date string for the date object
          event.value = util.printd(cFormatDate, oNewDate);
          • 2. Re: Script for Auto Date + 30 days
            Nyein Aung Level 1
            Hey,Thank you so much for that.unfortunately I can only get the today date to work.
            I went into page properties, selected run Java Script,copied and pasted the code you sent and changed the field names.
            I'm using a mac. Is there something I could be doing wrong?If you don't mind, could you walk me through how to set up the second date?I'm an absolute stranger to Java and programming.
            Thank you so much again.
            Date: Wed, 25 Nov 2009 07:57:23 -0700
            To: nyein.aung@hotmail.com
            Subject: Acrobat Scripting Script for Auto Date + 30 days
            var fNewDate = fDate + (30 * 24 * 60 * 60 * 60 * 1000);
