4 Replies Latest reply on Nov 27, 2009 3:54 AM by Crow Jane
    Snap to grid
    Crow Jane
      This probably has a really obvious answer but then the most frustratingly simple things do!
      I am using the grid in illustrator and the snap option to make clean even shapes. The problem is that when i have made a shape and want to reproduce it, once it has copied and pasted, it sits off the grid slightly, and therefor doesn't snap to the same places as the other shapes.
      HOW do i fix this?! Any clues?
      Ta
      Jane
        • 1. Re: Snap to grid
          Wade_Zimmerman Level 7
          It works fine here on a Mac with CS 4 on OS 10.6.2 I have video that shows it works as expected if you woud like to see it.
          I think if we knew whatt version of AI you are using and what system we could tell you how to reset the preferences.
          here is a screenshot of my settings but I do not think that is the problem.
          To reset the preferences the quick way is to hold down the Command Option Shift keys on the Mac when launching AI you hold the keys down firs and keep them held until launched on the PC hold the Alt Control Shift r trash and or move the Adobe Illustrator Settings folder in the users prefernces on a Mac and in Documents and Settings on the PC, I thin. some one will come along to give yu better windos instructions.
          • 2. Re: Snap to grid
            Check the zoom level. Snapping is tied to the magnification and thus effectively is dependent on what pixel data is used for the preview. 100% is recommended. Usually, at 200% zoom things level off, though. Zooming in further then does not seem to influence snapping any more.
            Mylenium
            • 3. Re: Snap to grid
              At 300% on the Mac it works fine here no problems?
              • 4. Re: Snap to grid
                Crow Jane Level 1
                Sorry it took so long to reply! Zooming to 100% and even 300% didn't work (i'm on CS3 by the way), but actually I think once the obbject is pasted, if you nudge it to the grid using the arrow keys that seems to work and it then picks up where it should lie.
                Thanks for your help anyway!
                Jane
