0 Replies Latest reply on Nov 24, 2009 8:50 AM by Paul Reilly
    [svn:fx-trunk] 12166: * A small batch of compiler fixes.
    Paul Reilly Level 1
      Revision: 12166
      Revision: 12166
      Author:   preilly@adobe.com
      Date:     2009-11-24 08:50:30 -0800 (Tue, 24 Nov 2009)
      Log Message:
      • A small batch of compiler fixes.
      QE notes:
      Doc notes:
      Bugs: SDK-23583, SDK-24378
      Reviewer: Corey
      Tests run: compilerperformance invalidation, checkintests
      Is noteworthy for integration: yes, turning strict on and off in FB
                                     should be fixed.
      Code-level description of changes:
        modules/compiler/src/java/flex2/compiler/SymbolTable.java
      • Removed newSymbolTable() and refactored the constructors to take
            a Configuration object.  The first constructor takes an existing
            ContextStatics and populates it.  The second constructor creates
            a new ContextStatics and then calls the first constructor.  This
            fixes SDK-23583.
        modules/webtier/j2ee/servlet/src/java/flex/webtier/server/j2ee/IncrementalCompileFilter.j ava
        modules/compiler/src/java/flex2/tools/oem/Application.java
        modules/compiler/src/java/flex2/tools/oem/Library.java
        modules/compiler/src/java/flex2/tools/WebTierAPI.java
        modules/compiler/src/java/flex2/tools/Fcsh.java
        modules/compiler/src/java/flex2/compiler/CompilerAPI.java
      • Updated to use new SymbolTable constructors.
        modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
        modules/compiler/src/java/flex2/tools/SwcChecksums.java
      • Updated areSwcFileChecksumsEqual() to take the theme CSS files
            into consideration when comparing the number of files in the swc
            context.  This fixes SDK-24378.
        modules/compiler/src/java/flex2/configuration_en.properties
      • Added message missing from revision 12043.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-23583
          http://bugs.adobe.com/jira/browse/SDK-24378
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/CompilerAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SymbolTable.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_en.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/Fcsh.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/SwcChecksums.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/WebTierAPI.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Application.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/Library.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/oem/internal/OEMUtil.java
          flex/sdk/trunk/modules/webtier/j2ee/servlet/src/java/flex/webtier/server/j2ee/Incremental CompileFilter.java
