3 Replies Latest reply on Nov 24, 2009 6:21 PM by kglad
    bring layer to front AND drag
    Angela Swift
      Hey guys, i've been receiving a ton of help here and love it but Im having a really bad time fixing this one part of an infographic im making.
      i need to do the following in a flash cs4/as2.0 file:
      1.) make all boxes draggable on the stage
      2.) on click/hover bring layer to the front.
      please check out my file. im just learning how to use array's and im almost there but still need a little help. thank you
      var city_arr:Array = new Array("THIS CONTAINS A LIST OF ALL MY CITIES I AM USING AS MY NAMING CONVENTION");
      //I GET CONFUSED ON THIS PART
      for (i=0;i<city_arr.length;i++){
           var citybox:String  = city_arr[i] + "_box";
           this[citybox]._visible = false;
           this[citybox].drag_mc.onMouseDown = function(){
                this._parent.startDrag();
           this[citybox].drag_mc.onMouseUp = function(){
                this._parent.stopDrag();
           this[citybox].close_btn.onRelease = function(){
                this._parent._visible = false;
        • 1. Re: bring layer to front AND drag
          don't use mousedown and mouseup events.  all your objects will respond to the mouse no matter the mouse's location.
          try:
          var city_arr:Array = new Array(THIS CONTAINS A LIST OF ALL MY CITIES I AM USING AS MY NAMING CONVENTION);
               var citybox:String  = city_arr[i] + _box;
             this[citybox].drag_mc.onRollOver = function(){
                    this._parent.swapDepths(this._parent.getNextHighestDepth());
               this[citybox].drag_mc.onPress = function(){
               this[citybox].drag_mc.onRelease = function(){
          p.s.  i'm not sure you want to make all this not visible
          • 2. Re: bring layer to front AND drag
            Angela Swift Level 1
            that worked perfectly but now i need to figure out how to bring the box to the front on the first initial click of the house...when you click on new houses some pop-ups get lost behind others so i need to bring them to the front. can anyone help with that?
            • 3. Re: bring layer to front AND drag
              use the swapDepths() method of movieclips (as was done in your rollover).
