7 Replies Latest reply on Nov 25, 2009 8:25 AM by leonidas113
    Preserve 'selectedItem' on DataGrid AFTER dataProvider refresh
    leonidas113
      i created a Dashboard in which I have a barchart that gets its values from the selected item of the datagrid, the datagrid in itself is getting its data from an external xml file that gets updated every 10 minutes.
      The Data grid gets updated just fine but it clears the selected item wich in turn clears the barchart.
      How can i preserve the selected item of the datagrid after it has been updated with the new data????
      any help will be greatly apreciated.
        • 1. Re: Preserve 'selectedItem' on DataGrid AFTER dataProvider refresh
          ShankarFlex3
          You can store the selectedItem on itemClick event in a Global variable and use it to set after the dataProvider refresh.
          • 2. Re: Preserve 'selectedItem' on DataGrid AFTER dataProvider refresh
            leonidas113 Level 1
            could you post some code as to how to do so...
            Im fairly new to flex and ActionScript
            • 3. Re: Preserve 'selectedItem' on DataGrid AFTER dataProvider refresh
              ShankarFlex3 Level 2
              Attach your code, I will modify it.
              • 4. Re: Preserve 'selectedItem' on DataGrid AFTER dataProvider refresh
                Prabh Singh
                [Bindable]
                private var myDP:XML;
                myDP = 'yourDG'.selectedItem as XML;
                //After refresh
                yourDG.selectedItem = <use e4x to get the correct object from the xml structure based on the myDP object>
                • 5. Re: Preserve 'selectedItem' on DataGrid AFTER dataProvider refresh
                  leonidas113 Level 1
                  ShankarFlex3 wrote:
                  <mx:Application
                  xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" xmlns:ilog="http://www.ilog.com/2007/ilog/flex" styleName="bluish" backgroundGradientColors="[#055B97, #07A7DB]" backgroundGradientAlphas="[1.0, 1.0]" creationComplete="unitRPC.send();startApp()">
                  <mx:Script>
                  <![CDATA[
                  import mx.events.CollectionEvent;
                  import flash.utils.setInterval;
                  import mx.rpc.events.ResultEvent;
                  import utils.Util;
                  import mx.collections.ArrayCollection;
                  import flash.display.Sprite;
                  import flash.utils.*;
                  private function unitRPCResult(event:ResultEvent):void
                  units=event.result.root.Interval;
                  total=event.result.root.Interval;
                  Bindable]
                  private var units:ArrayCollection=new ArrayCollection();
                  Bindable]
                  private var total:ArrayCollection=new ArrayCollection();
                  private function changeData(dataSet:String):void
                  //Determine which set should be loaded
                  switch (dataSet){
                  case ('set1'):
                  //Set URL target to Test Data 1
                  unitRPC.url =
                  "http://192.168.2.11:9090/myfile1.xml";
                  break;
                  case ('set2'):
                  //Set URL target to Test Data 2
                  totalRPC.url =
                  "http://192.168.2.11:9090/totals1.xml";
                  break;
                  default:
                  //If somehow it's neither, just leave it be
                  break;
                  //Send out new URL Request to refresh chart
                  unitRPC.send();
                  private var intervalDuration:Number = 10000 // Time in milliseconds
                  private function startApp():void
                  setInterval(changeData, intervalDuration,
                  'set1');
                  Bindable]
                  private var selectedItems:Array;
                  </mx:Script>
                  <mx:Binding
                  source="dg.selectedItems" destination="selectedItems" />
                  <mx:SeriesInterpolate
                  id="changeEffect" duration="1000"/>
                  <mx:HTTPService
                  id="unitRPC" url=http://192.168.2.11:9090/myfile1.xml result="unitRPCResult(event)"/>
                  <mx:HTTPService
                  id="totalRPC" url="http://192.168.2.11:9090/totals1.xml" result="unitRPCResult(event)"/>
                  <mx:VBox x="151" y="46" width="100%" height="90%" id="vbox4">
                  <mx:Panel width="95%" height="100%" layout="absolute" id="panel1">
                  <mx:ColumnChart x="0" y="0" id="CallChart" width="100%" height="100%" dataProvider="{selectedItems}">
                  <mx:horizontalAxis>
                  <mx:CategoryAxis categoryField="Time"/>
                  </mx:horizontalAxis>
                  <mx:series>
                  <mx:ColumnSeries showDataEffect="changeEffect" displayName="Answered" yField="Answer"/>
                  <mx:ColumnSeries showDataEffect="changeEffect" displayName="Dropped" yField="Dropped"/>
                  <mx:ColumnSeries showDataEffect="changeEffect" displayName="Xfer" yField="Xfer"/>
                  </mx:series>
                  </mx:ColumnChart>
                  <mx:Legend dataProvider="{CallChart}" right="10" top="10" id="legend1"/>
                  </mx:Panel>
                  <mx:DataGrid x="0" y="0" width="95%" height="100%" editable="false" id="dg" dataProvider="{units}" resizableColumns="true">
                  <mx:columns>
                  <mx:DataGridColumn headerText="Interval" dataField="Time"/>
                  <mx:DataGridColumn headerText="Answer" dataField="Answer"/>
                  <mx:DataGridColumn headerText="Dropped" dataField="Dropped"/>
                  <mx:DataGridColumn headerText="Xfer" dataField="Xfer"/>
                  <mx:DataGridColumn headerText="Average Talk Time" dataField="ATT"/>
                  </mx:columns>
                  </mx:DataGrid>
                  </mx:VBox>
                  • 6. Re: Preserve 'selectedItem' on DataGrid AFTER dataProvider refresh
                         All the bold italic font text are changed or added. I hope this should work
                         import mx.events.ListEvent;
                         public var crntObj:Object = new Object();
                            dg.selectedItem = crntObj;
                        //add a new function
                        private function storeObject(event:ListEvent):void
                              crntObj = event.currentTarget.selectedItem as Object;
                    <mx:DataGrid x="0" y="0" width="95%" height="100%" editable="false" id="dg" dataProvider="{units}" itemClick="storeObject(event)" resizableColumns="true">
                        <mx:columns>
                        </mx:columns>
                    </mx:DataGrid>
                    • 7. Re: Preserve 'selectedItem' on DataGrid AFTER dataProvider refresh
                      leonidas113 Level 1
                      I get this error message:
                      TypeError: Error #1009: Cannot access a property or method of a null object reference.
                      at KodakDash/unitRPCResult()[C:\Documents and Settings\zwing\My Documents\Flex Builder 3\KodakDash\src\KodakDash.mxml:20]
                      at KodakDash/__unitRPC_result()[C:\Documents and Settings\zwing\My Documents\Flex Builder 3\KodakDash\src\KodakDash.mxml:58]
                      at flash.events::EventDispatcher/dispatchEventFunction()
                      at flash.events::EventDispatcher/dispatchEvent()
                      at mx.rpc.http.mxml::HTTPService/http://www.adobe.com/2006/flex/mx/internal::dispatchRpcEvent()[C:\autobuild\3.2.0\framewor ks\projects\rpc\src\mx\rpc\http\mxml\HTTPService.as:290]
                      at mx.rpc::AbstractInvoker/http://www.adobe.com/2006/flex/mx/internal::resultHandler()[C:\autobuild\3.2.0\frameworks\ projects\rpc\src\mx\rpc\AbstractInvoker.as:193]
                      at mx.rpc::Responder/result()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\Responde r.as:43]
                      at mx.rpc::AsyncRequest/acknowledge()[C:\autobuild\3.2.0\frameworks\projects\rpc\src\mx\rpc\ AsyncRequest.as:74]
                      at DirectHTTPMessageResponder/completeHandler()[C:\autobuild\3.2.0\frameworks\projects\rpc\s rc\mx\messaging\channels\DirectHTTPChannel.as:403]
                      And it does not keep the selected item after the datagrid has refreshed
