3 Replies Latest reply on Nov 25, 2009 8:11 AM by Subeesh Arakkan
    Removing a Column from an ArrayCollection
    MrFork Level 1
      Hello All,
      As the subject header states, how does one remove a whole column from an array. So for example I have this scenario;
      var removeColumn:String = 'value';
      var myData:ArrayCollection =
      {month:"Jan", value:2000}
      delete removeColumn from myData
      So therefore the array is just:
      {month:"Jan"}
      {month:"Jan"}
      {month:"Jan"}
      Anyone have any ideas / workarounds?
        • 1. Re: Removing a Column from an ArrayCollection
          Subeesh Arakkan Level 4
          I am not sure if this is the best approach but the following function will work for you
                         private function removeColumn(coll:ArrayCollection, columnName:String):ArrayCollection
                              var newColl:ArrayCollection=new ArrayCollection();
                              for each (var item:Object in coll)
                                   var obj:Object=new Object();
                                   for (var column:String in item)
                                        if (column != columnName)
                                             obj[column]=item[column];
                                   newColl.addItem(obj);
                              return newColl;
          • 2. Re: Removing a Column from an ArrayCollection
            Gregor K Level 1
            He'd probably get better traction with
            columnName:String) : void
                                     delete item[columnName];
            • 3. Re: Removing a Column from an ArrayCollection
              Yes, that is the better option
