5 Replies Latest reply on Nov 25, 2009 10:38 AM by SheiD
    Percent of a Field
    SheiD
      Hello all...
      I'm very lost trying to do what I thought was a simple calculation in Acrobat Pro 9.
      I have two rows of fields. Row A is the base value entered by the user. Row B will calculate based off of the values of Row A.
      For the purpose of explaining, I will call the Fields in Row A Field1a, Field2a, Field3a and the fields in Row B Field1b, Field2b and Field3b etc.
      The different fields in Row B use different calculations. For example, Field1b is equal to Field1a. Field 2b is equal to Field2a x 5. Field3b is equal to Field3a x .1
      This is where I'm having trouble.
      How do I set up calculations so that Field2b = (Field1a x 5) ?
      Or so that Field3b = (Field3a/10) ?
      on Field3b I tried:
      var c = this.getField(“Field3a”);
      event.value = c.value * 0.1;
      But it keeps saying there is an illegal character on line 2.
      Any help would be very appreciated.
        • 1. Re: Percent of a Field
          1. The problem is you're using non-standard quotes (you're probably using a non-English keyboard layout) in your first line.
          Try replacing that line with this one:
          var c = this.getField("Field3a");
          2. You don't need JS for this. You can use the simplified annotaion script. Just write the field's name and the rest of the formula, like so:
          Field3a * 0.1
          • 2. Re: Percent of a Field
            SheiD Level 1
            Oh... duh. I'm sorry. I didn't know how to do the simple script either.
            I am not using a non-English keyboard. o_o so I have no idea why that happened with the quotations.
            As for the simple script, it isn't working.
            I entered the calculations like so:
            in Fieldb1, : Fielda1 * 5
            or
            Fieldb1, : Fielda1 * 0.1
            And when I close form editing and enter a value into Fielda1, the field stays blank.
            I don't know what's wrong.
            Thank you for the help so far!
            • 3. Re: Percent of a Field
              Do you maybe have spaces in the names of your real fields?
              • 4. Re: Percent of a Field
                SheiD Level 1
                No, they are named : S.1 , S.2 , S.3 Etc
                Do I need to change the . part?
                • 5. Re: Percent of a Field
                  SheiD Level 1
                  I changed them to S1 S2 S3 etc and it is working now!
                  Excellent! Thank you so much for your help. I am sorry I am so dense at this.
                  You have really helped me today! Thank you!
