0 Replies Latest reply on Nov 25, 2009 11:22 AM by Carol L. Frampton
    [svn:fx-trunk] 12205: TLF Build 557+.
    Carol L. Frampton
      Revision: 12205
      Revision: 12205
      Author:   cframpto@adobe.com
      Date:     2009-11-25 11:22:17 -0800 (Wed, 25 Nov 2009)
      Log Message:
      TLF Build 557+.  This is a private build from Rich because the TLF build machine is having issues and hasn't built in a few days.  Even though it is labeled as 557 it has the 559 fixes in it.
      Build 559
      • Fix for 2491564 bound links not updating. Turns out if you defined in mxml a TextFlow that had bound children but no contents (textLength = 0), it was normalizing out the bound children.
      • Fix Watson 2491430 TLF is updating scroll values but not sending scroll event
      • Fix 2489062 RTE in ScrollToRange when range positions are past the end of the flow
      • Fix 2486475 DeleteText Followed By Undo Can Some Paragraph Attributes
      • Fix 2491505 Add FlowOperationBegin/FlowOperationEnd events for Composite Operations
      Build 558
      • Fix 2487491 add ability to turn off TextLineRecycler for flash pro
           - use TextLineRecycler.textLineRecyclerEnabled
      • Fix 2489004 Use Explicit Existence Testing Instead of Capabilities.version for Argo APIs
      Build 557
      • Fix 2487386 Mutating InlineGraphicElement.source while Graphic is loading Fails.
      • Fix 2487386 Fix Watson 2485262, pointFormat not applied when entering text via inline IME.
      • Fix 2485151 Undo fires from right alt-z on Polish programmer's keyboard in Windows
      Build 555
      • Fix 2476623 Backspacing Doesn't Remember Pending Attributes
      • Fix 2486448 RTE when changing textFlow property on RichEditableText after clicking link in component
      QE notes:
      Doc notes:
      Bugs: SDK-24350, SDK-22895
      Reviewer: Gordon
      Tests run: checkintests, TextArea
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24350
          http://bugs.adobe.com/jira/browse/SDK-24317
          http://bugs.adobe.com/jira/browse/SDK-22895
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/BaseCompose.a s
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/FlowComposerB ase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextFlowLine. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextLineRecyc ler.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ContainerCo ntroller.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/HtmlImport er.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/EditManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/IMEClient.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/ISelectionManage r.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionFormat. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionManager .as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/edit/SelectionState.a s
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/Configuratio n.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowGroupEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/FlowValueHol der.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/InlineGraphi cElement.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/LinkElement. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/ParagraphEle ment.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextFlow.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/elements/TextRange.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/StringTextLin eFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/ITextLayoutFo rmat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor mat.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matInc.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/ApplyForma tOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/ClearForma tOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/DeleteText Operation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/FlowElemen tOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/InsertInli neGraphicOperation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/InsertText Operation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/EnumStringPr operty.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/IntWithEnumP roperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/NumberOrPerc entOrEnumProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/NumberWithEn umProperty.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/Property.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/property/UintWithEnum Property.as
          flex/sdk/trunk/frameworks/projects/textLayout/tlf.properties
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.557.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.554.swf
