4 Replies Latest reply on Nov 25, 2009 9:02 PM by neviusaga
    Basic help with jerky video...preset problem?
    neviusaga
      I'm a graphic design student but new to Premiere, and I'm having trouble with simple edits of video files taken by my digital camera. I made a simple test video using 2 different clips that fade in, use a cross dissolve to transition between them and then fade out. The video exported is terribly jerky and I suspect the preset or export settings are incorrect. I feel bad asking such a newbie question but I haven't had much luck searching google for help, maybe because I'm using a point and shoot digital camera's video files with this high level program. If anyone could give me some advice or direct me to a resource to start from I'd really appreciate it. Thanks for reading.
      System Specs:
      Adobe Master Collection CS4 (Premiere Pro CS4)
      Win 7 64 bit
      AMD Phenom X4 3.2GH quad core processor
      Gigabyte HD 5750 video card
      4 GB Ram
      1 TB HDD
      Camera:
      Sony Cybershot DSC T-200
      MediaInfo has this to say about a video file taken by my camera:
      Format                           : MPEG-PS
      Overall bit rate                 : 2 912 Kbps
      Video
      Format                                 : MPEG Video
      Format version                    : Version 1
      Format settings, Matrix     : Default
      Bit rate mode                    : Variable
      Bit rate                         : 2 732 Kbps
      Width                            : 640 pixels
      Height                           : 480 pixels
      Display aspect ratio             : 4:3
      Frame rate                       : 25.000 fps
      Scan type                        : Progressive
      Bits/(Pixel*Frame)               : 0.356
      Stream size                      : 21.8 MiB (94%)
      Audio
      Format                           : MPEG Audio
      Format profile                   : Layer 2
      Bit rate mode                    : Constant
      Bit rate                         : 64.0 Kbps
      Channel(s)                       : 1 channel
      Sampling rate                    : 32.0 KHz
      Resolution                       : 16 bits
      Stream size                      : 520 KiB (2%)
