Objective: to modify the sourceFilePath for Items in a
library using a Command.
The FLASH documentation states that sourceFilePath must use
absolute path. However, by copying the movie clip from my master
library into a development library the property sourceFilePath is
originally relative.
Here is the jsfl that FLASH created.
// This command was recorded by Macromedia Flash 8.
// Select Library Item(s): p2
fl.getDocumentDOM().library.selectItem('p2');
// Symbol Properties: movie clip, false, false, false,
.\MasterTestLib.fla, p2, true, false
var lib = fl.getDocumentDOM().library;
lib.setItemProperty('symbolType', 'movie clip');
if (lib.getItemProperty('linkageImportForRS') == true) {
lib.setItemProperty('linkageImportForRS', false);
else {
lib.setItemProperty('linkageExportForAS', false);
lib.setItemProperty('linkageExportForRS', false);
lib.setItemProperty('sourceFilePath','.\\MasterTestLib.fla');
lib.setItemProperty('sourceLibraryName','p2');
lib.setItemProperty('sourceAutoUpdate',true);
lib.setItemProperty('scalingGrid', false);
By running this as FLASH created, causes the following error
to occur:
[Invalid URI: ?s?s?s?s?s?s?t?s?t?t?s?t%12f0c4]
[setItemProperty: Argument number 1 is invalid.]
Changing the sourceFilePath by using the Browse button within
the Properties Dialogue Box for a library item created jsfl with an
absolute path referred to in the documentation:
lib.setItemProperty('sourceFilePath','C:\\Documents and
Settings\\aylwardm\\Desktop\\MasterTestLib.fla');
Regardless of the format that FLASH reports to me in the jsfl
that is generated, when I attempt to set the item by running the
jsfl as a Command the same error occurs.
Anybody able to help me???
