3 Replies Latest reply on Nov 27, 2009 2:45 AM by Bogdan Manate
    access database
    sagisid Level 1
      is it possible to connect or use database built in MSAccess ? i am developing a standalone application.
        • 1. Re: access database
          Matt Le Fevre Level 4
          As far as i know, no.
          I tried to find this out a while back, before i managed to convince my team to move to mySQL, and the most informative answer i found was
          The answer would be no.
          Flex can talk to servers, via standard TCP/IP protocols, but it doesn't do
          ODBC as it's cross-platform. Knowing Microsoft though there's probably a
          very easy way to expose web services from .net that access the MDB via a DSN
          There's a .net launcher for AIR that you could use, and put all your data
          access in the .net side of things, but besides knowing of its existence and
          how it works, that's all I know about it.
          And shame on you for using Access ;-)
          • 2. Re: access database
            sagisid Level 1
            hey Grizzzzzzz....
            i did the same thing.
            convinced my team to move to MySQL....
            • 3. Re: access database
              Bogdan Manate
              If you managed to concince your team to use MySQL you can find here (
              http://code.google.com/p/as3flexdb/ ) a very useful library wich will help
              you to connect to MySQL.
