12 Replies Latest reply on Nov 28, 2009 2:42 AM by dgwillia1982
    Assigning result of a match to a variable
    dgwillia1982
      I am trying to assign the result of a match (regular expression) to a variable. The code below throws an error:
      urlManipulation = titleString.match (/(((http|ftp|https):\/\/){1}([a-zA-Z0-9_-]+)(\.[a-zA-Z0-9_-]+)+([\S,:\/\.\?=a-zA-Z0-9_-] +))/igs));
      Compiler says it was expecting right brace before right paren
      I am pretty sure there is nothing wrong with the reg expression but instead the syntax of the assignment I am trying to perform
      Any ideas?
        • 1. Re: Assigning result of a match to a variable
          Subeesh Arakkan Level 4
          Try this
          urlManipulation = titleString.match(new RegExp("/(((http|ftp|https):\/\/){1}([a-zA-Z0-9_-]+)(\.[a-zA-Z0-9_-]+)+([\S,:\/\.\?=a- zA-Z0-9_-]+))/","igs"));
          • 2. Re: Assigning result of a match to a variable
            dgwillia1982 Level 1
            Thanks for that.
            However, I know get the following error...
            Implicit Coercion of a value of type Array to an unrelated type String.
            However both variables have been defined as Strings so I dont understand this. I have pasted more code below
            [Bindable]
                        private var resultArrayCollection:ArrayCollection;
                        private var titleString:String;
                        private var urlManipulation:String;
                        private function onResult (e:ResultEvent):void
                            resultArrayCollection = e.result.feed.entry as ArrayCollection;
                            for(var count:int = 0; count < resultArrayCollection.length; count++)
                                titleString = resultArrayCollection[count].title;
                                urlManipulation = titleString.match(new RegExp("/(((http|ftp|https):\/\/){1}([a-zA-Z0-9_-]+)(\.[a-zA-Z0-9_-]+)+([\S,:\/ \.\?=a- zA-Z0-9_-]+))/","igs"));
                                trace(urlManipulation);
                                trace(titleString);
                </mx:Script>
            Can you help?
            • 3. Re: Assigning result of a match to a variable
              String.match() returns you an array of strings consisting of all substrings in   the string that match the specified pattern.
              urlManipulation should be an array.You can check the length of the array and access the string like
              urlManipulation[ 0 ] ( first item in the array )
              Check this page for more info
              http://livedocs.adobe.com/flex/3/langref/String.html#match%28%29
              • 4. Re: Assigning result of a match to a variable
                Thanks, I think I am getting there.
                One other problem now though, the array length is 0, and I know it should contain matches. When I trace the array it comes back with Undefined. Also the Length when I debug is 0. My updated code is below:
                <mx:Script>
                        <![CDATA[
                            import mx.collections.ArrayCollection;
                            import mx.rpc.events.ResultEvent;
                            [Bindable]
                            private var urlManipulation:Array;
                                    trace(urlManipulation[0]);
                                    trace(titleString);
                    </mx:Script>
                Does anything stand out as being wrong?
                • 5. Re: Assigning result of a match to a variable
                  It could be the forward slashes in the regex or the flags ( igs )
                  check with this
                  match(new RegExp("(((http|ftp|https):\/\/){1}([a-zA-Z0-9_-]+)(\.[a-zA-Z0-9_-]+)+([\S,:\/\.\?=a- zA-Z0-9_-]+))","igs"));
                  • 6. Re: Assigning result of a match to a variable
                    This worked for me
                    var str:String = "http://www.google.com";
                    var arr:Array = str.match(new RegExp("(((http|ftp|https):\/\/){1}([a-zA-Z0-9_-]+)(\.[a-zA-Z0-9_-]+)+([\S,:\/\.\?=a-zA-Z 0-9_-]+))","igs"));
                    • 7. Re: Assigning result of a match to a variable
                      This did solve the undefined problem, but now the Regular expression you provided, does not stop at whitespace.
                      For instance it brings back results such as
                      - http://google.com this is a great site
                      rather thanjust
                      - http://google.com
                      Do you know what changes I can make to the Regular expression to make sure it only brings back the URL? Logically I would like it to search fro 'http' then bring back any characters after that up until a space.
                      any ideas?
                      • 8. Re: Assigning result of a match to a variable
                        This will work for you
                        var str:String = "http://www.google.com cvcvcv";
                        var arr:Array = str.match(new RegExp("^((ht|f)tp(s?)\:\/\/|~/|/)?([w]{2}([\w\-]+\.)+([\w]{2,5}))?(:[\d]{1,5})?+([a-zA-Z 0-9\/\_\?\.\,\&]+)?","igs"))
                        Also check this link.You will find good regex examples here
                        http://ryanswanson.com/regexp/#start
                        • 9. Re: Assigning result of a match to a variable
                          Thanks again for your help, unfortunately the reg expression you provided above results in the undefined error again.
                          I have pasted the latest code below, in case there is anything else you can think of?
                          <mx:Script>
                                  <![CDATA[
                                      [Bindable]
                                              var arr:Array = titleString.match(new RegExp("^((ht|f)tp(s?)\:\/\/|~/|/)?([w]{2}([\w\-]+\.)+([\w]{2,5}))?(:[\d]{1,5}) ?+([a-zA-Z0-9\/\_\?\.\,\&]+)?","igs"));
                                              trace(arr[0]);
                                              trace(titleString);
                              </mx:Script>
                          • 10. Re: Assigning result of a match to a variable
                            there should not be any white space inside the regular expression.
                            match(new RegExp("^((ht|f)tp(s?)\:\/\/|~/|/)?([w]{2}([\w\-]+\.)+([\w]{2,5}))?(:[\d]{1,5})?+([a-zA-Z0-9\/\_\?\.\,\&]+)?","igs"))
                            • 11. Re: Assigning result of a match to a variable
                              the above reg exp just brings back the first word within the string now.
                              <mx:Script>
                                      <![CDATA[
                                          [Bindable]
                                                  var arr:Array = titleString.match(new RegExp("^((ht|f)tp(s?)\:\/\/|~/|/)?([w]{2}([\w\-]+\.)+([\w]{2,5}))?(:[\d]{1,5})?+([a-zA-Z 0-9\/\_\?\.\,\&]+)?","igs"));
                                                  trace(arr[0]);
                                                  trace(titleString);
                                  </mx:Script>
                              • 12. Re: Assigning result of a match to a variable
                                looks like problem solvec with following reg expression...
                                var arr:Array = titleString.match(new RegExp(/(((http|ftp|https):\/\/){1}([a-zA-Z0-9_-]+)(\.[a-zA-Z0-9_-]+)+([\S,:\/\.\?=a-zA-Z 0-9_-]+))/igs));
