1. Re: How can I edit the right-click context menu?
Omke Oudeman Nov 28, 2009 2:24 AM (in response to theMikeD)Could be caused by several things I believe.
You have already checked you have only one application folder with one Adobe
app for each in it on your Disk?
Also look in the preferences in Bridge under file type associations for the
given extensions, do they also show double applications?
Try first to refresh preferences with restart Bridge holding down option
key, it is the first aid for Bridge and curing many problems.
Also use Disk Utility to check and repair permissions for your OS.
I seem to have two entries for every Adobe product when I right-click a file
and choose "Open With..." Is there a way to either clean it out automatically,
or fix this myself?
2. Re: How can I edit the right-click context menu?
theMikeD Nov 28, 2009 4:13 PM (in response to Omke Oudeman)I have one folder for each app, and I reset the Bridge preferences, and I still get the dual listings. And it's not just for the Adobe apps, it's for everything under the "Open with..." flyout menu.
3. Re: How can I edit the right-click context menu?
Omke Oudeman Nov 29, 2009 3:17 AM (in response to theMikeD)You might want to create a new user on your system just for testing. If this
test user account does not have this problem it lies in your current user
account.
And I do understand correctly that you have only one application folder and
this is at root level on your system, so not inside the user account itself?
