8 Replies Latest reply on Nov 30, 2009 11:26 AM by jason_y
    concatenating string in cache query
    jason_y
      I was wondering if I concatenate strings within the query I write in a <cfquery> tag with dbtype="query"?
      I want to do something similar to the following:
      <cfquery name="a_query" dbtype="query">
           SELECT
                ('$ ' + TotalProfit) AS TotalProfit2
           FROM SomeCachedQuery
      </cfquery>
      I can do this if the query is run on the SQL server, but not with the cached query.If this is not possible, is there some code I can wirte that does the same thing?
      Thanks!
      Jason
        • 1. Re: concatenating string in cache query
          Dan Bracuk Level 5
          Since you can do it in the original sql, you should.  If you want to do it in ColdFusion, look at the query functions such as queryaddcolumn and querysetcell.
          • 2. Re: concatenating string in cache query
            BKBK Adobe Community Professional & MVP
                 SELECT
            </cfquery>
            That is quite possible. In fact, it is so common you will come across it all over the place.
            Just to confirm: what you're trying to do should be something like
            <cfquery name="SomeQuery" datasource="someDSN">
                 SELECT TotalProfit
                 FROM someTable
            </cfquery>
                 SELECT ('$ ' + TotalProfit) AS TotalProfit2
                 FROM SomeQuery
            </cfquery>
            • 3. Re: concatenating string in cache query
              Adam Cameron. Level 5
                   FROM SomeQuery
              </cfquery>
              Does this actually work for you?  It doesn't for me, unless I case TotalProfit to be a varchar, first.
              Adam
              • 4. Re: concatenating string in cache query
                -==cfSearching==- Level 4
                As Adam said, you need to cast the value to a varchar first. Either in the original query or within the QoQ:
                     SELECT '$ '+ CAST(TotalProfit AS VARCHAR)  AS TotalProfit2
                     FROM      SomeQuery
                However, you could just use NumberFormat() in your output. Unless there is some reason you need to do this in a QoQ..
                #NumberFormat(SomeQuery.TotalProfit, "$-9999999.00")#
                • 5. Re: concatenating string in cache query
                       FROM SomeQuery
                  </cfquery>
                  Adam
                  Yes, Adam, it works for me. But then, I take it for granted TotalProfit is of type char or varchar. The title and Jason_y's opening phrase("I was wondering if I concatenate strings") give that impression.
                  • 6. Re: concatenating string in cache query
                         FROM SomeQuery
                    </cfquery>
                    Well... sure.  To concatenate one string ("$") to something else, both are going to have to end up being strings at some stage.  But it seems unlikely that a column that:
                    a) is having a dollar-sign applied to the beginning of its value;
                    b) is called "TotalProfit";
                    is going to be a string to start with.
                    Still... stranger things have happened, I guess.
                    Adam
                    • 7. Re: concatenating string in cache query
                      Dan Bracuk Level 5
                      If the concatonation is static text to a db field, a simple way to do it is in the output, not in the query.
                      • 8. Re: concatenating string in cache query
                        jason_y Level 1
                        Hi All,
                        Thanks for your help. The TotalProfit column in my original query is a numeric field and casting it in the QofQ did the trick. The reason I wanted to add the dollar sign in the query instead of a <cfouput> is I wanted to use the result of the query and bind it to a cfgrid (HTML version). This tag had attributes that allow you to add numberformat / dollarformat, but they're only for the Flash version of the cfgrid. It was unavailable for the HTML version. I considered using the Flash version, but this version did not allow you to bind data to the grid. I wanted the page navigation / column sorting that binding allows.
                        I'm not too sure why cfgrid have different attributes for different grid types. I kinda wish the binding and the number format both exist at the same time.
                        Jason
