14 Replies Latest reply on Nov 30, 2009 6:12 AM by David_F57
    module that doesn't scale 100% to its container
    nikos101 Level 2
      I have a module that doesn't scale 100% to its container
      <mx:Module xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical"
          percentWidth="100" percentHeight="100" verticalGap="0"
          <mx:creationComplete>
              <![CDATA[
              vo = VO.getInstance();
          </mx:creationComplete>
          <mx:Script>
      You see anything wrong?
        • 1. Re: module that doesn't scale 100% to its container
          David_F57 Level 5
          first up I would try width="100%" height="100%" and layout="absolute", then make sure your container has no padding set.
          David.
          • 2. Re: module that doesn't scale 100% to its container
            David_F57 Level 5
            One more thing if you are instantiating as per our earlier discussion you could set the width and height property there
            lm.height=container.height;
            lm.width=container.width;
            David.
            • 3. Re: module that doesn't scale 100% to its container
              nikos101 Level 2
              Thanks but no such luck
              I've got the following structure
              Superpanel  (resizable component that extends  panel)
                   module width ="100%" height = 100%
                        Hbox width ="100%"
                        datagrid width ="100%" height = 100%
              the Hbox and   datagrid  are tiny little things that should grow with the
              Superpanel
              • 4. Re: module that doesn't scale 100% to its container
                David_F57 Level 5
                So what is the module going into the panel ?
                how about setting top/left/bottom/right to 0;
                • 5. Re: module that doesn't scale 100% to its container
                  nikos101 Level 2
                  I set up the panel like this
                  privileges= new SuperPanel();
                          privileges.x=0;
                          privileges.y=0;
                          privileges.width=725;
                          privileges.height=500;
                          privileges.verticalScrollPolicy='off';
                          privileges.allowDrag=true;
                          privileges.allowResize=true;
                          privileges.allowClose=true;
                          privileges.allowMaximize=true;
                          privileges.allowMinimize=true;
                          privileges.addEventListener(CloseEvent.CLOSE,privilegesClose)
                          privileges.layout='vertical';
                          privileges.title="Assign privileges";
                          privileges.addChild(privilegesML);
                  then I load the module
                            privilegesML.url = 'modules/Privileges.swf';
                  The module looks a bit like this
                  <mx:Module xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" paddingBottom="0" paddingLeft="0" paddingRight="0" paddingTop="0"
                      width="100%" height="100%" verticalGap="0"
                          <![CDATA[
                      <mx:HBox width="100%">
                          <mx:Button label="Save changes to server" click="deals.dataProvider=tradesResult">
                              <mx:icon>@Embed(source='../../images/32px-Crystal_Clear_app_kwrite.png')</mx:icon>
                          </mx:Button>
                          <mx:Button label="Refresh list" icon="@Embed(source='../../images/cog.png')" click="myService.getUsers();"/>
                      </mx:HBox>
                      <mx:AdvancedDataGrid id="deals" displayItemsExpanded="false" dataProvider="{vo.usersResult}" width="100%" height="100%" sortExpertMode="true" variableRowHeight="true" headerStyleName="smallHeader" editable="false" fontWeight="normal">
                          <mx:columns>
                              <mx:AdvancedDataGridColumn dataField="name" headerText="User name" width="120" textAlign="center" editable="false"/>
                              <mx:AdvancedDataGridColumn headerText="Add trade" width="70" editorDataField="addTradeView" rendererIsEditor="true" backgroundColor="0xddf5ff">
                                  <mx:itemRenderer>
                                      <mx:Component>
                                              <mx:CheckBox >
                      <mx:Script>
                                                  <![CDATA[
                                                      override public function set data(value:Object):void
                                                          super.data=value;
                                                          if(value != null){
                                                          this.selected=this.data.addTradeView;
                                              </mx:Script>
                                                  <mx:change>
                                                      <![CDATA[
                                                      this.data.isModifiedClientSide = 1;
                                                      this.data.addTradeView = this.selected; //used to check through data and update server
                                                  </mx:change>
                                              </mx:CheckBox>
                                      </mx:Component>
                                  </mx:itemRenderer>
                              </mx:AdvancedDataGridColumn>
                          </mx:columns>
                      </mx:AdvancedDataGrid>
                  </mx:Module>
                  • 6. Re: module that doesn't scale 100% to its container
                    nikos101 Level 2
                    I think I'll need to just make to with absolute widths I guess, so sad
                    best wishes
                    Nikos Katsikanis (Msci)
                    Web Developer
                    • 7. Re: module that doesn't scale 100% to its container
                      David_F57 Level 5
                      Ok,
                      so the module fills the super panel completely, you can keep you layout for the module to suit how it is populated but for the panel I think the layout should not be vertical as when you resize it the module won't resize correctly
                      so
                      1- load the module, privelegesML.url=myModule;
                      2-set module parameters,  privelegesML.top=privelegesML.bottom=privelegesML.left=privelegesML.right=0;
                      3-add PrivelegesML to the panel;
                      i'm sorta guessing here as i'm rebuilding my dev pc so no flashbuilder for a few hours.
                      David
                      • 8. Re: module that doesn't scale 100% to its container
                        nikos101 Level 2
                        Something really weird happens when using this module stuff
                        if I do
                        dealsCanvas.getChildByName('privileges');
                        I get a null object, I am convinced that this should not be the case as in
                        the variables privileges.parent.id = dealsCanvas
                        best wishes
                        Nikos
                        • 9. Re: module that doesn't scale 100% to its container
                          nikos101 Level 2
                          Multiple markers at this line: -1119: Access of possibly undefined property right through a
                          reference with static type modules:CustomModuleLoader. -1119: Access of possibly undefined
                          property bottom through a reference with static type modules:CustomModuleLoader. -1119:
                          Access of possibly undefined property top through a reference with static type
                          modules:CustomModuleLoader. -1119: Access of possibly undefined property left through a
                          • 10. Re: module that doesn't scale 100% to its container
                            David_F57 Level 5
                            I've just finished reinstalling FB so give it about 30 minutes I'll see what I can come up with.
                            David
                            • 11. Re: module that doesn't scale 100% to its container
                              David_F57 Level 5
                              http://gumbo.flashhub.net/modsizer/ (view source enabled)
                              Its a slap together and the resizing isn't perfect but is this what you are trying to achieve ?
                              David
                              • 12. Re: module that doesn't scale 100% to its container
                                nikos101 Level 2
                                Yours work the way I want thanks, but my Flex 3 one still has the problems. Thanks anyway and nice use of the FB4
                                • 13. Re: module that doesn't scale 100% to its container
                                  nikos101 Level 2
                                  That custom panel you wrote is cool, I wonder how easy it would be to not allow draging when you try resize the columns in the DG, or interact with any of the child components?
                                  • 14. Re: module that doesn't scale 100% to its container
                                    David_F57 Level 5
                                    if its done as a skin things work better(heres some code for you to play with)
                                    http://gumbo.flashhub.net/sizer/
                                    this was my original effort, look at the skin code (i don't think this thing had move enabled) i can't find the code but I did a skin and it only moved with the mousedown on the caption.
                                    David
