5 Replies Latest reply on Nov 28, 2009 12:17 PM by pascal@1direction.com
    java.io.FileInputStream init problem on Linux
      I'm using the code below since a while on a ColdFusion hosting on Windows platform. Now I try to install on a Linux server and I get this error (on working code):
      Object Instantiation Exception.An exception occurred when instantiating a Java object. The class must not be an interface or an abstract class. Error: ''.
      Here is the code extract. The error occurs on the marked line.
      Anybody knows how to solve this?
        <cfscript>
         prefix = ucase(left(name,find(".properties",name)-1));
         languages = listAppend(languages,prefix);
         // these objects enable getResourceBundle method to load the properties files:
         rb  = createObject("java", "java.util.PropertyResourceBundle");
         fis = createObject("java", "java.io.FileInputStream");
         if( not isDefined("application.rb_#prefix#")) {
          fis.init(application.translationpath&prefix&'.properties');
          rb.init(variables.fis);
          "application.rb_#prefix#" = rb;
         fis.close();
        </cfscript>
        • 1. Re: java.io.FileInputStream init problem on Linux
          BKBK Adobe Community Professional & MVP
          I think the problem isn't the line fis = createObject("java", "java.io.FileInputStream");, but the line after that. It should be an assignment of the form a=b. Something like this should work:
          <cfscript>
             // fis and rb enable getResourceBundle method to load the properties files:
              variables.fis = createObject("java", "java.io.FileInputStream").init(application.translationpath&prefix&'.properties');
              variables.rb = createObject("java", "java.util.PropertyResourceBundle").init(variables.fis);
              "application.rb_#prefix#" = variables.rb;
              variables.fis.close();
          </cfscript>
          In fact, this is even more efficient, as you will only need to create the objects when isDefined() returns true.
          • 2. Re: java.io.FileInputStream init problem on Linux
            pascal@1direction.com Level 1
            I trief with your suggestion, but still the error.
            The error occurred in /var/opt/coldfusion8/wwwroot/hosts/www.backup.habimat.be/Application.cfm: line 46
            44 :      // fis and rb enable getResourceBundle method to load the properties files:
            45 :      if (not isDefined("application.rb_#prefix#")) {
            46 :         variables.fis = createObject("java", "java.io.FileInputStream").init(application.translationpath&prefix&'.properties ');
            47 :         variables.rb = createObject("java", "java.util.PropertyResourceBundle").init(variables.fis);
            48 :         "application.rb_#prefix#" = variables.rb;
            • 3. Re: java.io.FileInputStream init problem on Linux
              Make sure this line -- neater without the extra space at the end -- represents a string that represents the full path to a properties file. What happens when you replace it with
              "#application.translationpath&prefix&'.properties'#"
              • 4. Re: java.io.FileInputStream init problem on Linux
                Still the same :-( I tried just removing the trailing space and adding the # signs.
                46 :         variables.fis = createObject("java", "java.io.FileInputStream").init(#application.translationpath#&#prefix#&'.properties');
                • 5. Re: java.io.FileInputStream init problem on Linux
                  OK it works...the most stupid Windows <> Linux mistake...
                  tried to load NL.properties while it should be nl.properties.
                  Thanks for the help!
