Dear Community,
I will appreciate your help or comments on this one.
I am using cp4, I have slide with audio and a rollover slidelet (no audio here), I selected the option "stop slide audio when slidelet appears".
When I preview Next 5 slides, the slide audio does not stop, (the progress bar shows a pause in the slide).
I have copied the entire slide (slidelet included) and paste it on a new CP file, and it works fine (the slide audio stops when the rollover slidelet appears).
So I copy and paste it back again to the original project (slide 5 original) so it was placed on slide #6. I have previewed the project and on slide 5 the same problem occurs on slide 6 was working fine. Then I deleted slide number 5....and after previewing the project guess what....yes... is not working!!!!
I was wondering what is happening with the slide number 5....is there a setting or something preventing this to work correctly.
Thank you in advance.
Santi
Hi Santi,
Sometimes Captivate goes nuts like this and a solution that normally works is to copy all your existing slides to a blank project. Try and create a new blank project in Captivate with the same dimensions and then copy / paste all your slides into that. This usually helps with this type of problems.
/Michael
Visit my Captivate blog with tips & tricks, tutorials and Widgets.
Dear Michael,
Thank you for your email.
I have tried copying the all the slides into a blank cp4 project, but the problem still occurs (slide audio does not stop when rollover slidelet appears).
(This does not happens all the time, this occurs in a few slidelets)
I have inserted a blank slide before the slide with the problem, and this is solving the issue.
Also instead of inserting a blank slide I have tried copying the previous slide, remove the sound and make it short (0.5 sec) and this also works.
I believe this last option is a good workaround, I wonder what is causing the issue or if I might be doing something wrong.
Best regards,
Santi
Santi, I think you have hit on the best solution. In fact, I always use a duplicate slide without audio at the end of every file to make sure the audio from one Captivate file doesn't 'bleed over' when the next file opens. --Leslie
