1 Reply Latest reply on Nov 28, 2009 7:29 PM by wlupoli
    .dxf files with illustrator 10?
    wlupoli
      Can I import .dxf files into illustrator 10?
        • 1. Re: .dxf files with illustrator 10?
          Wade_Zimmerman Level 6
          Yes as well as dwg though some of the newer versions of AutoCAD files might not open or open properly.
          If you are in a pinch then you can save the CAD files as eps and tht will open.
          Or perhaps PDF.
          You can also export to .dxf and dwg File>Export
          You can either open the dxf file in Illustrator or place it in a opened document.
