0 Replies Latest reply on Nov 30, 2009 7:51 AM by Paul Reilly
    [svn:fx-trunk] 12270: * Another batch of compiler fixes.
    Paul Reilly Level 1
      Revision: 12270
      Revision: 12270
      Author:   preilly@adobe.com
      Date:     2009-11-30 07:51:06 -0800 (Mon, 30 Nov 2009)
      Log Message:
      • Another batch of compiler fixes.
      QE notes:
      Doc notes:
      Bugs: SDK-24083, SDK-24084, SDK-23721, SDK-24386
      Reviewer: Corey
      Tests run: checkintests
      Is noteworthy for integration: yes, fixes DMV issue and FB issue
      Code-level description of changes:
        modules/compiler/src/java/flex2/tools/PreLink.java
          Revert a last minute change, which I made before revision 12043,
          by moving the while loop back outside the for loop.  Otherwise the
          iterator only gets created once inside the for loop.  This fixes
          SDK-23721 and SDK-24386.
        modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
          Modified stripRedeclaredManagementVars() by checking if classInfo
          is null before using it.  It can be null when errors have
          occurred.  This helped reveal the problem with SDK-24083 and
          SDK-24084.
        modules/compiler/src/java/flex2/compiler/SourceList.java
          Modified calculateRelativePath() to better handle multiple
          directories which overlap by name.  This fixes SDK-24083 and
          SDK-24084.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24083
          http://bugs.adobe.com/jira/browse/SDK-24084
          http://bugs.adobe.com/jira/browse/SDK-23721
          http://bugs.adobe.com/jira/browse/SDK-24386
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/SourceList.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/as3/SyntaxTreeEvaluator.java
          flex/sdk/trunk/modules/compiler/src/java/flex2/tools/PreLink.java
