2 Replies Latest reply on Nov 30, 2009 2:25 PM by msakrejda
    Functions: how first-class are they?
    msakrejda Level 4
      One of my favorite things about Flex is first-class functions. They make my life easy. I recently wanted to add some utility functions to my app, and since Flex has first-class functions, I thought to myself, I can just define them outside of a class, instead of having to define (and use, more importantly) static methods on a class. Apparently, FlexBuilder does not like this--it does not complain about the definition, but when I try to use it, it does not recognize that the symbol is defined. Is there a way to define publically visible first-class functions (rather than static methods), like escape, isNaN, trace, etc? Ideally, I'd like these in a package or namespace, but I'm curious in any case.
        • 1. Re: Functions: how first-class are they?
          paul.williams Level 4
          I believe you can, but the rules for public functions are similar to those for classes:
          Only one public function per AS file
          Filename must match public function name
          Public function must be placed within a package declaration
          Private functions must be placed outside and after package declaration
          You must import the function before you use it
          Eg:
          package funcs
              public function publicFunc() : int
                  return 4 + privateFuncA() * privateFuncB();
          function privateFuncA() : int
              return 4;
          function privateFuncB() : int
              return 2;
          You would use the above by importing publicFunc and then calling it:
          import funcs.publicFunc;
          var result : int = publicFunc();
          • 2. Re: Functions: how first-class are they?
            msakrejda Level 4
            These are what I was missing. It's working now--thank you.
