0 Replies Latest reply on Nov 30, 2009 1:25 PM by Paul Reilly
    [svn:fx-trunk] 12294: * Fix for error reporting bug.
    Paul Reilly Level 1
      Revision: 12294
      Revision: 12294
      Author:   preilly@adobe.com
      Date:     2009-11-30 13:25:28 -0800 (Mon, 30 Nov 2009)
      Log Message:
      • Fix for error reporting bug.  The bug was caused by a warning being
        reported during one compilation and then an error being reported in
        a following compilation.  Due to the warning, the Source's logger
        was disconnected instead of being nulled out during the first
        compilation.  Then in the second compilation, we weren't reassigning
        the logger, so the disconnected logger was being left in place.  As
        a result, it was throwing off expected error counts and caused an
        assert to fire.
      QE notes: There is probably an easier way to reproduce the assertion
                that George hit without having to create multiple projects
                and without having to manually copy SWC's around.  I didn't
                realize this until I had a fix, though.  One key aspect that
                George didn't note and might not have realized, is that the
                variable needs to cause a warning, so leaving off a
                namespace works, but making it public, private, etc doesn't.
      Doc notes:
      Bugs: SDK-24314
      Reviewer: Corey
      Tests run: checkintests
      Is noteworthy for integration: fixes FB issue
      Code-level description of changes:
        Modified setLogger() to always reassign logger.
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24314
      Modified Paths:
          flex/sdk/trunk/modules/compiler/src/java/flex2/compiler/Source.java
