4 Replies Latest reply on Dec 2, 2009 3:30 AM by JulienFR
    erase blank text Frames in document
    JulienFR Level 1
      I have many blank text frames in my documents. i want to erase them with a script.
      I try this script but there return an error sometimes "undefine"... "not an object"
      this : (IT'S WRONG CODE DO NOT COPY).
         app.findGrepPreferences = app.changeGrepPreferences = null;
         app.findGrepPreferences.findWhat = '\\A\\Z';
         var blocsvides = app.activeDocument.findGrep (true);
         for (var i = 0; i < blocsvides.length; i++)
            blocsvides[i].parentTextFrames[0].remove()                   // <---- in this line there are an error
      there're many frames in my documents, image, text and undefined objet with color too.
      Thanks to help me. :-)
      Julien.
        • 1. Re: erase blank text Frames in document
          Harbs. Level 6
          Try something like this:
          var stories = app.documents[0].stories.everyItem().getElements();
          for(var i=0;i<stories.length;i++){
            if(stories[i].contents==""){
              var containers = stories[i].textContainers;
              while (c=containers.pop()){
                c.remove();
          Harbs
          • 2. Re: erase blank text Frames in document
            JulienFR Level 1
            yes. thanks Harbs. you're very rapid.
            it's perfect if you don't have color back frame.
            I have many text frames with nothing or just color back. It's strange because when i slide from Illustrator window an object directly in my InD documents (or Copy/paste), they becomes Text object or image object. So with your script it's erase all :-))).
            I think to try create an popup to choose if you want color back or simply all text frame.
            what do u think about this idea? extended to image bloc?
            finally it miss an "identical selection"as in Illustrator.
            Thanks.
            • 3. Re: erase blank text Frames in document
              Harbs. Level 6
              This should leave any visible frames:
              var noColor = app.documents[0].swatches.item(0);
                      if(c.fillColor != noColor){continue}
                      if(c.strokeColor != noColor && c.strokeWeight > 0){continue}
                    c.remove();
              • 4. Re: erase blank text Frames in document
                JulienFR Level 1
                it's perfect!
                nice job !
                Thank you.
                (i understand nothing of your code... i gonna learn C and C++ . after i'll learn javascript. )
