2 Replies Latest reply on Jan 20, 2010 1:35 PM by Sean S Murphy
    Virtual classroom using Stratus?
    onlinelanguagelabs
      Can Stratus be used in a virtual classroom envrionment with a flash-based whiteboard, screen sharing etc? If not, is it possible to run audio-video over Stratus and - in parallel - run the virtual classroom components over Flash Media Server?
        • 1. Re: Virtual classroom using Stratus?
          bom33
          In script add this:
          private var ringerSound:Sound;
          in your program's inti() function add this:
          this.ringerSound = new Sound(new URLRequest("http://lukeidiot.com/chat/ring.mp3"));
          then play the sound on the function that handles the incoming call:
          messageSound.play();
          • 2. Re: Virtual classroom using Stratus?
            Sean S Murphy Level 1
            I've made a collaboration application that demonstrates all the principles you would need to build your own flash based virtual classroom using only stratus (and a peer sharing app/site). http://www.murphysean.com/?p=37
            I'll break it down a little bit:
            The whiteboard could be drawn by sending continuosly the mouse position to all the other peers, and the state of the  mouse position (is it drawing, perhaps a color)
            The audio/video is basically built into flash for you, minus aec (Audio Echo Cancellation) because adobe is not sharing their proprietary tech with the community... See here I demonstrate sharing audio/video/chat/and file sharing (which could be implemented better)
            You could also buy into the adobe service LCCS which provides everything you are talking about in an api.
