5 Replies Latest reply on Nov 30, 2009 3:39 PM by Peter deHaan
    DateField one month off
    schipmold Level 1
      Has anyone else had any problems with the date of the datefield?
      When I set the selectedDate property the month displayed is actually one higher then the month I give it.
      However, when using the date picker it does show the date I selected...
      I tried different ways of setting the date, but to no avail...
      My code:
      startDate = new Date();
      startDate.date = 15;
      startDate.month = 09;
      startDate.fullYear = 2009;
      <mx:DateField editable="true" formatString="DD/MM/YYYY" selectedDate="{startDate}"/>
      output: 15/10/2009
        • 1. Re: DateField one month off
          mewk Level 3
          Date::month begins at zero.
          • 2. Re: DateField one month off
            schipmold Level 1
            Ahh thanks a million.
            Can't believe I missed that... I must be getting tired
            • 3. Re: DateField one month off
              mewk Level 3
              it happens
              can't blame you though -- day begins at 1 but month at 0??
              • 4. Re: DateField one month off
                Peter deHaan Level 4
                Blame Player.
                Dates are usually a lot easier if you just create some static constants for the Month names:
                            private var startDate:Date;
                            private const JAN:uint = 0;
                            private const FEB:uint = 1;
                            private const MAR:uint = 2;
                            private const APR:uint = 3;
                            private const MAY:uint = 4;
                            private const JUN:uint = 5;
                            private const JUL:uint = 6;
                            private const AUG:uint = 7;
                            private const SEP:uint = 8;
                            private const OCT:uint = 9;
                            private const NOV:uint = 10;
                            private const DEC:uint = 11;
                            private function init():void {
                                startDate = new Date(2009, SEP, 15);
                        <mx:DateField id="df" editable="true" formatString="DD/MM/YYYY" selectedDate="{startDate}"/>
                        <s:Button click="init();" />
                • 5. Re: DateField one month off
                  schipmold Level 1
                  Thanks for the tip Peter.
                  The thing is that my dates come from a database and are in integer format so I'll try the string format next time
                  All's working fine now, so thanks both.
