0 Replies Latest reply on Nov 30, 2009 2:29 PM by jmurphy67
    [svn:fx-trunk] 12298: Localization property file update 4.0.0.12295
    jmurphy67 Level 1
      Revision: 12298
      Revision: 12298
      Author:   jimurphy@adobe.com
      Date:     2009-11-30 14:29:17 -0800 (Mon, 30 Nov 2009)
      Log Message:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/SharedResources.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/formatters.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ja_JP/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ja_JP/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/SharedResources.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/core.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/controls.properties
          flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/core.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_da.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_de.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_es.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fi.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_fr.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_it.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ja.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ko.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nb.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_nl.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_pt.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_ru.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_sv.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_CN.properties
          flex/sdk/trunk/modules/compiler/src/java/flex2/configuration_zh_TW.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_da.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_de.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_es.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_fi.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_fr.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_it.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_ja.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_ko.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_nb.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_nl.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_pt.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_ru.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_sv.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_zh_CN.properties
          flex/sdk/trunk/modules/fxgutils/src/java/com/adobe/fxg/FXGException_zh_TW.properties
