0 Replies Latest reply on Nov 30, 2009 2:51 PM by Jason Szeto
    [svn:fx-trunk] 12300: PopUpAnchor effects bug fix
    Jason Szeto Level 3
      Revision: 12300
      Revision: 12300
      Author:   jszeto@adobe.com
      Date:     2009-11-30 14:51:26 -0800 (Mon, 30 Nov 2009)
      Log Message:
      http://bugs.adobe.com/jira/browse/SDK-24187 - PopUpAnchor removal changes width/height of popup, causing artifacts with any effects
      Changed PopUpAnchor logic so that we only capture the popUp size the first time it is popped up. We no longer restore the value when the popup is removed. Instead, we restore the value when we open the popUp and we aren't forcing the size to match the anchor.
      QE notes: None
      Doc notes: None
      Bugs: SDK-24187
      Reviewer: Chet
      Tests run: PopUpAnchor, ComboBox, DropDownList
      Is noteworthy for integration: No
      Ticket Links:
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/PopUpAnchor.as
