0 Replies Latest reply: Nov 30, 2009 3:00 PM by rfrishbe RSS
    [svn:fx-trunk] 12302: Cleaning up ASDoc for skins.
    rfrishbe Community Member
      Revision: 12302
      Revision: 12302
      Author:   rfrishbe@adobe.com
      Date:     2009-11-30 14:59:51 -0800 (Mon, 30 Nov 2009)
      Log Message:
      Cleaning up ASDoc for skins.  We now use "@copy" for ASDocs.  I also tried to find all places where there were id's and either document them or mark them as "@private".
      Unfortunately, @copy can't be placed in the beginning of an ASDoc but must be placed at the end.  I filed a new bug for this.
      Also, I forgot to copy some MuteButton skin changes to the fullscreen and wireframe versions.  Those changes were initially code reviewed by Kevin.
      QE notes: -
      Doc notes: Would be nice to briefly take a look at the skin ASDocs to make sure they look ok.  There are a lot of files, and it's relatively low-priority IMO, though.
      Bugs: SDK-22459
      Reviewer: No one--just doc changes
      Tests run: checkintests
      Is noteworthy for integration: No
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-22459
      Modified Paths:
          flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/SparkChromeWindowedAppl icationSkin.mxml
          flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/WindowedApplicationSkin .mxml
          flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/windowChrome/MacTitleBa rSkin.mxml
          flex/sdk/trunk/frameworks/projects/airspark/src/spark/skins/spark/windowChrome/TitleBarSk in.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ApplicationSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarFirstButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarLastButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarMiddleButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ComboBoxTextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DefaultComplexItemRenderer .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListButtonSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/DropDownListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/HSliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ListSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/NumericStepperTextInputSki n.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/RadioButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarDownButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarLeftButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarRightButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollBarUpButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ScrollerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SkinnableContainerSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SkinnableDataContainerSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerDecrementButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerIncrementButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/SpinnerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TabBarButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TabBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextAreaSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TitleWindowCloseButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/TitleWindowSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/ToggleButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VScrollBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VSliderTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/VideoPlayerSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Fu llScreenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Mu teButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Pl ayPauseButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Sc rubBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Sc rubBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Sc rubBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Vo lumeBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Vo lumeBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/fullScreen/Vo lumeBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/FullSc reenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/MuteBu ttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/PlayPa useButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/ScrubB arTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/mediaClasses/normal/Volume BarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ApplicationSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarFirstButt onSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarLastButto nSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarMiddleBut tonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/CheckBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ComboBoxButtonSkin .mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ComboBoxSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DefaultButtonSkin. mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DropDownListButton Skin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/DropDownListSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HScrollBarSkin.mxm l
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HScrollBarThumbSki n.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HScrollBarTrackSki n.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HSliderThumbSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/HSliderTrackSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ListSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/NumericStepperSkin .mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/NumericStepperText InputSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/PanelSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/RadioButtonSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ScrollBarDownButto nSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ScrollBarLeftButto nSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ScrollBarRightButt onSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ScrollBarUpButtonS kin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/SpinnerDecrementBu ttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/SpinnerIncrementBu ttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/SpinnerSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TabBarButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TabBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TextAreaSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TextInputSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TitleWindowCloseBu ttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/TitleWindowSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/ToggleButtonSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VScrollBarSkin.mxm l
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VScrollBarThumbSki n.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VScrollBarTrackSki n.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VSliderSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VSliderThumbSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VSliderTrackSkin.m xml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/VideoPlayerSkin.mx ml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/FullS creenButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/MuteB uttonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/PlayP auseButtonSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Scrub BarSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Scrub BarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Scrub BarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Volum eBarSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Volum eBarThumbSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/Volum eBarTrackSkin.mxml
          flex/sdk/trunk/frameworks/projects/wireframe/src/spark/skins/wireframe/mediaClasses/fullS creen/FullScreenButtonSkin.mxml
