0 Replies Latest reply on Dec 1, 2009 6:25 AM by Carol L. Frampton
    [svn:fx-trunk] 12321: TLF Build 562.
    Carol L. Frampton Level 2
      Revision: 12321
      Revision: 12321
      Author:   cframpto@adobe.com
      Date:     2009-12-01 06:25:50 -0800 (Tue, 01 Dec 2009)
      Log Message:
      TLF Build 562.  Our previous build was a private build of 557+.
      Build 562
      • Fix 2491878 Page Down and Page Up don't work properly in the linked containers
      Build 561
      • Fix 2491514 Bug Fix For 2467353 Disabled TextLineRecycling In Normal Editing
      Build 558
      • Fix 2491945 FXGImporter/FXGExporter Not Deleted. These files were never deleted from the code even though they are never used.
      • Fix for 2491564 bound links not updating. Turns out if you defined in mxml a TextFlow that had bound children but no contents (textLength = 0), it was normalizing out the bound children.
      • Fix 2491430 TLF is updating scroll values but not sending scroll event
      • Fix 2489062 RTE in ScrollToRange when range positions are past the end of the flow
      • Fix 2486475 DeleteText Followed By Undo Can Some Paragraph Attributes
      • Fix 2491505 Add FlowOperationBegin/FlowOperationEnd events for Composite Operations
      • Fix 2487639 Some constructors should have code moved to an initialize function for jitting
      • Fix 2487491 add ability to turn off TextLineRecycler for flash pro
           - use TextLineRecycler.textLineRecyclerEnabled
      • Fix 2489004 Use Explicit Existence Testing Instead of Capabilities.version for Argo APIs
      QE notes:
      Doc notes:
      Bugs:
      Reviewer:
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-24350
      Modified Paths:
          flex/sdk/trunk/frameworks/air-config.xml
          flex/sdk/trunk/frameworks/flex-config.xml
          flex/sdk/trunk/frameworks/libs/textLayout.swc
          flex/sdk/trunk/frameworks/projects/textLayout/ReleaseNotes.txt
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/BuildInfo.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/FlowComposerB ase.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextFlowLine. as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/compose/TextLineRecyc ler.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/ContainerCo ntroller.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/container/TextContain erManager.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/factory/StringTextLin eFactory.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/formats/TextLayoutFor matValueHolder.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/operations/InsertText Operation.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/utils/NavigationUtil. as
      Added Paths:
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.562.swf
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/FXGExporte r.as
          flex/sdk/trunk/frameworks/projects/textLayout/src/flashx/textLayout/conversion/FXGImporte r.as
          flex/sdk/trunk/frameworks/rsls/textLayout_1.0.0.557.swf
