1 Reply Latest reply on Dec 3, 2009 1:46 PM by DawMatt
    Lua soap integration in lightroom
    ravi Kishore K
      HI ,
      I AM USING LUA SOAP AND LUA SOCKET TO CALL THE  WEB SERVICE. IT IS WORKING FINE WHEN I TRIED TO CALL THE WEBSERVICE WITHOUT INTEGRATING WITH LIGHTROOM PLUGIN.
      WHEN I TRIED TO INTEGRATE THE PLUGIN WITH THE LIGHTROOM IT SI UNABEL TO LOAD THE LUA SOCKET FILES.
      PLEASE TELL HOW TO INTEGRATE THE SOAP FILES WITH LIGHT ROOM.
      THE FOLLOWIN GERROR I AM GETTING WHILE INTEGRATING WITH LIGHTROOM.
      An error occurred while attempting to run one of the plug-in’s scripts.
      error loading module 'ssl.core' from file '/opt/local/lib/lua/5.1/ssl.so':
      dynamic libraries not enabled; check your Lua installation
      **** Error 2
      Could not load the post-processing filter from this plug-in.
      Please tell me the solution asap
        • 1. Re: Lua soap integration in lightroom
          DawMatt Level 3
          I'm pretty sure the functionality you are trying to access is disabled.  The LR SDK limits the LUA standard capabilities available to the developer and I'd be extremely surprised if they allowed us to load object files.  If it was an option I'm sure Jeffrey Friedl wouldn't have had to take such a torturous path to get SHA1 digests working.
          So I think your best option is to ask for SOAP support to be integrated into Lightroom because that publicly available module will not work within the environment provided by the SDK.
          Matt
